New user Emby problem
Introduce yourself here
gavinc
Post by gavinc » 03 May 2018, 19:08
First post after trying out the lite version on my Shield TV and Emby connecting great so i plumped for the paid version. That was 24 hours ago and nothing changed until I started up Shield TV tonight. Emby connected OK , then I close MrMC and it appears to be updating because it says "installing" on the Shield app!!.
I restart MrMC and all settings have gone and its a clean install. I try and reconnect to Emby server. The server confirms MrMC has connected but nothing shows up in MrMC.
Someone please advise whats happening and how I correct it. Its not the server its MRMC, are there logs and how do I get them to post?
Re: New user Emby problem
Post by amet » 03 May 2018, 19:40
Debuglog has all the info
gavinc
Post by gavinc » 05 May 2018, 13:37
Hi
Debug log posted: https://pastebin.com/n3SwyWZz
Tried re-installing many times and just can't get it to work
Post by amet » 05 May 2018, 15:52
it signed in ok, I dont see that you tried entering Movies or Tv Show section
as debuglog instructions say, please do not post logs in the forum... use pastebin for that
gavinc
Post by gavinc » 06 May 2018, 07:26
Yes I know it signs in OK . On the Emby server that is confirmed, but on MrMC after I've logged in to the server I go back to the main page and there is no Movies or TV option in the GUI? When I tried to connect to the server first time on Lite it worked and immediately there where the Movies and TV options listed. Now this wont work.
Post by davilla » 06 May 2018, 17:09
what comes back if you open 'http://192.168.1.72:8096/emby/system/info/public' in a browser ?
gavinc
Post by gavinc » 06 May 2018, 22:00
06 May 2018, 17:09
Hi It gives me the server wan address server name and operating system.
Post by davilla » 06 May 2018, 23:57
let me be more specific. Mine shows (WanAddress has been hidden)
{"LocalAddress":"http://192.168.2.109:8096","WanAddress":"http://xx.xx.xx.xx:yyyy","ServerName":"DAVILLA-QNAP","Version":"3.2.3.0","OperatingSystem":"Linux","Id":"9fc34651027b49d7946fad1e9e3ca131"}
Does yours also show LocalAddress ? Matches "192.168.1.72" ?
gavinc
Post by gavinc » 08 May 2018, 14:07
06 May 2018, 23:57
Hi, yes mine shows the local server address.
However things have moved on. Today I have just loaded MrMC and Movies and TVShows have appeared. Its working so its a bit of a mystery why it wasn't before.! Anyway all is good now so this thread can be closed.
Thanks for your replies. :D
