Hello and how to automatically remove deleted videos
Introduce yourself here
blenky
Post by blenky » 25 Apr 2018, 20:06
Hi. I used XBMC back in the day (actually on an XBOX!) and moved onto both Kodi and SPMC on my Nvidia Shield'
I've purchased MrMc and finding it really good so far.
I have one niggle that I can't seem to figure out. I have got update at start up enabled and any new TV or Movie videos are added. However how do I get videos that have been deleted removed on start up?
Re: Hello and how to automatically remove deleted videos
Post by amet » 26 Apr 2018, 09:51
for that you need to run clean library, we did not hook that in on startup intentionally ... if your drive is not connected on start, clean will remove all items from your library... you have to manually initiate the Clean function
vitorjc
Post by vitorjc » 02 May 2018, 16:30
Is there a possibility to do that by adding a parameter on a config XML file like Kodi and SPMC?
Post by davilla » 02 May 2018, 19:51
I assume you mean via AdvancedSettings.xml ? Yes, that file is supported in MrMC.
bigscrap
Post by bigscrap » 15 May 2018, 13:00
Why don't autoclear every connected drive only? I believe you can check if connected at startup.
Post by davilla » 15 May 2018, 13:44
This issue has been endlessly rehashed over many decades at xbmc/kodi. The end result is always never auto delete anything. The risk is way to high that something bad will happen and someone deletes their entire 10TBs of contents.
