Navigation: Last line cut off (Movies / Series)  [SOLVED]
venrael
Post by venrael » 11 Jan 2019, 21:48
First - I really love your product and everything in my opinion works fine. There's just this little thing with the navigation / display of the last row of movies or series.
The navigation scrollbar is at the end but as you can see in the picture... the last line of images isn't displayed full.
Do you know this problem?
The yellow line below in the picture is the TV frame bottom.
Is there a solution to it? I don't want to change the view...
Any hint / help would be appreciated.
Re: Navigation: Last line cut off (Movies / Series)
Post by davilla » 11 Jan 2019, 23:26
venrael wrote:
11 Jan 2019, 21:48
The navigation scroll bar is at the end but as you can see in the picture... the last line of images isn't displayed full.
Not a bug but a feature, it's a visual hint that there are more items below.
venrael
Post by venrael » 11 Jan 2019, 23:30
Thanks for the reply.
The problem is ... the next down click on the remote brings me to the first top row again.
Like I wrote... the scrollbar on the right is on the end position... I can't scroll down any further. The images in the last row remain "hidden". This happens in all libraries. (I can send you a video link in a private message if it helps to clarify the problem.)
Can you guys please look into it?
Is anyone else experiencing this problem?
Re: Navigation: Last line cut off (Movies / Series)  [SOLVED]
Post by amet » 12 Jan 2019, 08:19
venrael
Post by venrael » 13 Jan 2019, 00:23
Thanks a lot for the quick and helpful reply.
Keep up the good work... :-)
