Bug resuming file of combined parts
Post by cosmoxl » 22 Jul 2017, 13:33
https://gist.github.com/anonymous/97c70 ... 8c30ebb926
There is the log, testing on the ATV4 with the siri remote.
The bug presents when trying to resume playback and the location of the playback is in the second part of the combined file.
From the Movies>In Progress section just clicking on the file results in no action. Holding down the pad and selecting "resume from xxx" results in no action. Holding down the pad and selecting movie information, then selecting play, then selecting "resume from xxx" results in a playback failed message.
From the main movies section (all movies are shown) the same results happen. Except, in this section there is a choice of "play from here" if I hold down the pad. Selecting "play from here" will resume the file at the proper location.
Re: Bug resuming file of combined parts
Post by cosmoxl » 22 Jul 2017, 13:37
Of note, this bug doesn't seem to affect the shield tv app.
Post by amet » 22 Jul 2017, 13:47
cosmoxl wrote:
22 Jul 2017, 13:37
will have a look, need to find something thats multi part and try .. shield tv app?
please kill Curl logging, makes it impossible to see whats going on in there :)
Post by cosmoxl » 22 Jul 2017, 13:53
22 Jul 2017, 13:47
cosmoxl wrote:
22 Jul 2017, 13:37
Yes, I mean MrMC on shield isn't affected.
I see the bug in MrMC on apple tv.
I'll kill curl logging next time.
Post by amet » 22 Jul 2017, 13:59
thats odd, is it the same version? code is exactly the same on both
Post by cosmoxl » 22 Jul 2017, 14:26
22 Jul 2017, 13:59
the apple tv is on the 3.1 testflight. but, that's not the cause of the problem.
I noticed this problem months ago, and even posted about it then, but it was just brought to my attention again last night. :)
Post by cosmoxl » 24 Jul 2017, 18:03
Amet, have you had a chance to look into this yet?
Post by amet » 24 Jul 2017, 18:47
cosmoxl wrote:
24 Jul 2017, 18:03
I just did, I cant reproduce with one movie that I have thats multipart... all devices run just fine and resume is ok on all
run it again without curl logging please, lets see if anything stands out
Post by cosmoxl » 24 Jul 2017, 19:19
ahhh..something jogged my memory and I recalled that when I first brought this bug to your attention you found that plex transcoding was involved in this bug. Sure enough, turning off plex transcoding allows it to work properly.
https://gist.github.com/anonymous/92a91 ... 94e8ecb450
In the log there I tested with transcoding on (doesn't work) and then with transcoding off.
