Pull the correct date for TV shows
Post by timstephens24 » 03 Jun 2017, 11:29
Right now the date for all the episodes using the Plex client is 01/01/YYYY with YYYY being the correct year the episode was first aired. It's there any way to pull the full date from Plex and not just the year? I'm using the Amber skin, but it's the same with the default skin if you use the 'Media info' view.
Re: Pull the correct date for TV shows
Post by amet » 04 Jun 2017, 04:34
I'd have to check if plex gives us correct date, if you look up episode info on plex webui, does it have correct date?
Post by timstephens24 » 04 Jun 2017, 10:27
Yup, the correct date's shown there, and in the metadata details it's labeled as 'Originally Available.'
randomjohn
Post by randomjohn » 25 Aug 2017, 17:03
Did anything ever come of this? Have same issue. Sometimes the year varies (I think it corresponds to the season) but the date is always 1/1 in MrMC even when it's correct in Plex. Thanks.
Post by davilla » 25 Aug 2017, 17:07
I think this one slipped through the cracks. Making a github issue for it.
https://github.com/MrMC/mrmc/issues/36
Post by amet » 26 Aug 2017, 15:00
I am not seeing this in Episodes, if I bring out media info it shows correct date.
EDIT: this is in current testflight
Post by timstephens24 » 26 Aug 2017, 15:20
I think this was fix but never mentioned. I see it in Amber, but the info isn't shown in new skin, soooooooooo...... <points to TestFlight thread>
Post by amet » 26 Aug 2017, 15:23
bring out episode info in the new skin, that has it all ok for me
Post by timstephens24 » 26 Aug 2017, 15:52
Ain't nobody got time to long press and look at the episode info :geek:
Post by davilla » 26 Aug 2017, 23:31
timstephens24 wrote:
26 Aug 2017, 15:20
So the date now show correctly in Amber ?
