Partially watched tv shows no longer visible
mitrestreet
Post by mitrestreet » 01 Feb 2017, 14:54
Using ATV4 and Amber skin (same issue occurs with other skins)
Once I start a TV show, if I menu out of it to anywhere else in the application before finishing watching it, when I come back, the episode is no longer showing on the list. I have to change from Sort Method List:Unwatched to List: All Videos to see the episode (which is correctly shown as partially watched). The unwatched counter in each level (show/season) does correctly show the episode as not yet completed.
I am pretty sure that this an issue with how Plex is supported, as it doesn't happen with the native library. Is there a way to fix this?
Re: Partially watched tv shows no longer visible
Post by amet » 01 Feb 2017, 15:28
I will have a look, thanks for letting us know
Post by timstephens24 » 01 Feb 2017, 20:39
This is the same for me. I thought I had reported it previously but maybe I forgot.
Post by cosmoxl » 01 Feb 2017, 20:46
I don't seem to have this problem.
my sort method is mediainfo sorted by playlist.
Antibus
Post by Antibus » 03 Feb 2017, 23:33
I've seen this too since converting to Plex. If I'm watching a show and simply back out (typically accidentally), it's disappeared from the list.
Post by timstephens24 » 04 Feb 2017, 00:08
I don't see partially watched shows or movies on the Apple TV and NVIDIA Shield when set to show 'unwatched only' with Plex as the database source.
convertapple
Post by convertapple » 10 Mar 2017, 13:29
Yes, I discovered this yesterday, had to switch to unwatched, then back again when done.
Post by amet » 10 Mar 2017, 18:05
this is Plex database, I see partially unwatched items... I am misunderstanding what the issue is? :(
Post by cosmoxl » 10 Mar 2017, 18:20
10 Mar 2017, 18:05
if unwatched only is selected then partially watched shows don't appear. people want partially watched shows to appear in the unwatched list (with triangle signifying partially watched) until they are fully watched.
Post by amet » 10 Mar 2017, 18:22
so not episodes, shows? correct?
