I bought MrMC yesterday and tried several times to run it on my 1st gen Fire TV (not stick) that has Kodi 16.0 side-loaded on it.
MrMC would launch to the MrMC logo screen then immediately crash back to the Fire TV home screen. I never saw the "first run" blue bar along the bottom or got the the Confluence home screen.
I finally went to "manage installed applications" and did a "clear data" under MrMC and it came up and ran fine, with no problem since. (although it took nearly a full minute to start).
Everything seems great so far, just wanted to give you a heads-up.
Sorry it's not a better bug report.
-Wes
Problems on first launch on Fire TV
Re: Problems on first launch on Fire TV
Odd, not seen that happen. I happen to have both, 1st and 2nd gen. Seems ok on both.
We do have changes planned for the launch period. Refactor and purge. Should be able to get 10X faster launch.
FYI I installed this on my other Fire TV and it launched the first time with no problem.
Maybe it was a fluke. Like I said, it worked after deleting the data on the first one (through the Fire TV app menu) so maybe something got corrupted on install).
