"Server - MrMc" -- what is this option?
sirmcftv
Post by sirmcftv » 29 Oct 2018, 19:06
Haven't looked at the MrMC software updates in a while. I now see an icon at the bottom that says "Server - MrMC" and when I click on it I get a list with a single choice MrMC. What other servers could show up in there? I do have Plex client configured and logged in, but not sure if it's considered a "server".
pecinko
Re: "Server - MrMc" -- what is this option?
Post by pecinko » 29 Oct 2018, 19:37
Mrmc, Plex and/or Emby can appear as servers of media content.
Post by davilla » 29 Oct 2018, 19:51
sirmcftv wrote:
29 Oct 2018, 19:06
Which Plex client, the internal client or the extension ? Only the internal emby/plex client will show up in that list.
sirmcftv
Post by sirmcftv » 29 Oct 2018, 20:40
Hmm, I had no idea there were two ... I disabled the extension and I'm signed in to the Plex Client. Still not seeing a Plex server in the list :( My Plex server is only accessible on the LAN, is that supposed to work? This is all very confusing :(
sirmcftv
Post by sirmcftv » 18 Nov 2018, 21:11
No ideas why the Plex server does not show up on the list?
Or, let me ask a different way: what is the best (proper?) setup when all the media files sit on a Linux server (local LAN) that shares via NFS and also there's a Plex server running on the same server?
Post by timstephens24 » 18 Nov 2018, 21:46
I generally use Plex since the updates are a lot faster. NFS isn't a bad option, but you have to wait for it to scrub in new files every time the app is opened or you have it update the library.
In 'Settings -> Services -> Plex Client' does that show you logged in to Plex?
##### SYNOLOGY 1815+ #####
sirmcftv
Post by sirmcftv » 18 Nov 2018, 21:53
timstephens24 wrote:
18 Nov 2018, 21:46
Yes, it does, I did the linking with PIN. This is an old install of the app and it's been configured to use NFS for a while now. Not sure whether there are conflicts between the 2 when both are configured. I'd expect under "Server" to see MrMC and perhaps also Plex and be able to switch between them -- is that not how it's supposed to work? But only MrMC shows up, no sign of the Plex server. I hope that the Plex server doesn't need to have remote access enabled as I don't want to do that.
I can try to uninstall and reinstall the MrMC app and start fresh by configuring Plex only, but I'd like to avoid redoing the rest of the settings.
Post by timstephens24 » 19 Nov 2018, 02:19
It probably needs remote access to verify the client at least once.
