Video playback OSD behavior changed on Firestick 2?
Since the update to MrMC 3.7 the OSD behavior appears broken during video playback on Firestick 2. With previous versions you could pull up the playback OSD (play, pause, FF, rewind, etc.) by pressing "ok" during playback on the firestick remote. Since the 3.7 release, pressing "ok" brings up the settings OSD instead. I can bring up the playback OSD by pressing "ok-up arrow" on the remote. But, this seems cumbersome. The previous behavior seems much more logical. Since there is no "stop" button on the firestick remote, I rely on the OSD to stop playback. Is there any way to restore the previous behavior?
Re: Video playback OSD behavior changed on Firestick 2?
I tried posting a debug.log to pastebin but it's too large to be accepted without creating an account. Here's a snippet of the debug log that's relevant to keypresses:
14:25:51.909 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:25:54.262 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:25:56.813 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
14:26:00.435 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:00.805 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:01.120 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:01.486 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:03.154 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:03.555 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:03.855 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:04.974 T:18446744072497301944 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
14:26:06.724 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:26:12.647 T:18446744072497301944 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
14:26:13.932 T:18446744072497301944 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
14:26:16.172 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:26:18.495 T:18446744072497301944 DEBUG: OnKey: right (0xf083) pressed, action is Right
14:26:18.974 T:18446744072497301944 DEBUG: OnKey: right (0xf083) pressed, action is Right
14:26:22.088 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
14:26:28.189 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:26:29.272 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:26:30.919 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:26:31.598 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:26:37.621 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:26:38.253 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:26:39.515 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:26:40.372 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:26:46.345 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:26:47.176 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:26:48.376 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:26:49.164 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:27:00.100 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:27:01.582 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:27:02.826 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is ChapterOrBigStepForward
14:27:04.805 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is ChapterOrBigStepBack
14:27:06.156 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is OSD
14:27:07.349 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:27:08.200 T:18446744072497301944 DEBUG: OnKey: right (0xf083) pressed, action is Right
14:27:08.418 T:18446744072497301944 DEBUG: OnKey: right (0xf083) pressed, action is Right
14:27:08.967 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
14:27:12.543 T:18446744072497301944 DEBUG: OnKey: right (0xf083) pressed, action is Right
14:27:13.894 T:18446744072497301944 DEBUG: OnKey: left (0xf082) pressed, action is Left
14:27:14.483 T:18446744072497301944 DEBUG: OnKey: left (0xf082) pressed, action is Left
14:27:16.864 T:18446744072497301944 DEBUG: OnKey: up (0xf080) pressed, action is Up
14:27:17.603 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
14:27:18.940 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
14:27:21.436 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:21.696 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:21.926 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:22.211 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:22.485 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:22.995 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
14:27:24.076 T:18446744072497301944 DEBUG: OnKey: right (0xf083) pressed, action is Right
14:27:25.097 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:25.365 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:25.632 T:18446744072497301944 DEBUG: OnKey: down (0xf081) pressed, action is Down
14:27:26.217 T:18446744072497301944 DEBUG: OnKey: return (0xf00d) pressed, action is Select
