3.7.0 video resume bug
Agentq
Post by Agentq » 22 Sep 2018, 04:05
Apparently since the 3.7.0 update videos no longer resume. I have not found a solution or workaround. Anyone else have this issue? I have a fire tv 4k (2nd Gen)
MrMolle
Re: 3.7.0 video resume bug
Post by MrMolle » 24 Sep 2018, 11:29
I have noticed the same (with Shield). The app doesn't present the dialog for resume/start for unfinished videos. However, you still get the option to resume in the contextual menu ('c' with a keyboard, long press 'Select' with the remote).
Post by amet » 24 Sep 2018, 11:36
Is that by going through select -> video info screen or by hitting play on remote(double tap volume bar)?
Plex or MrMC database?
MrMolle
Post by MrMolle » 24 Sep 2018, 11:46
24 Sep 2018, 11:36
All my videos are on a NAS which I have set as an SMB share in MrMC. I don't use Plex.
With the video file highlighted, long press the 'Select' button and you should be presented with the context menu.
Post by amet » 24 Sep 2018, 12:08
I know how to get to context menu, my question was about playback resume when attempting to play...
When does it fail to offer resume points? When using select and going through video info screen or when using play on remote control
Agentq
Post by Agentq » 24 Sep 2018, 23:13
My setup is connected to a synology Nas and I don't get any resume prompt after the update, it just plays from the beginning. I have now bought a nvidia shield to replace the fire tv since it plays HDR content with washed out colors.
Post by koying » 01 Oct 2018, 15:11
Testflight 3.7.1 for FireTV.
Please see https://forum.mrmc.tv/viewtopic.php?f=17&t=4466
