Fire TV 3 question/problems with deinterlacing, playback starting paused
alekseyz
Post by alekseyz » 11 Sep 2018, 14:13
Hi, I have been long time SPMC user (Thank you Koying!!!) on various Fire TV platforms and I bought MrMC a while ago but have not been using it much. With Fire TV 3 I now have problems with Mediacodec (Surface) and smooth 24p playback with SPMC (plain Mediacodec works, but then I lose HDR) and decided to give MrMC a try.
My setup: Amazon Fire TV 3 with Display "Resolution" set to "Auto", "Match original frame rate" set to "On" in Fire TV settings. Samsung MU8000 4K HDR TV, Fire TV directly connected to TV.
MrMC settings: UI in 720p, "Automatic refresh rate/resolution" set to "Always", "Pause after adjusting frame rate" set to "2 seconds". Under acceleration I have default setting "Mediacoded (surface)" enabled, "Mediacodec" disabled. 24p playback is smooth, thank you MrMC!
I have the following problems/question:
1. MPEG2 deinterlacing of 1080i from HDHomerun tuner through PVR HDHomerun addon is poor. Judging by the available deinterlacing options in the menu, decoding is done in software, because Yadif and others are present. How can I enable Amlogic hardware deinterlacer for MPEG2 live video from HDHomerun?
2. the first time after starting MrMC I start playback of 4K 60p HDR video file (e.g. Samsung The world in HDR demo), playback hangs on the first frame, no audio, no HDR. After I stop and start playing the same file again it plays fine. This only occurs on playing the first video after starting MrMC. I had the same problem with SPMC.
3. playback always starts "Paused" if refresh rate switching is on, this is not affected by changing "Pause after adjusting refrest rate" setting, and it only happens when i enable "Match original frame rate" in Fire TV 3 display settings. This looks like the same issue as this http://forum.mrmc.tv/viewtopic.php?f=17 ... c6c0fabc7f
Disabling refresh rate switching in not a fix for me. Without refresh rate switching 24p videos have lots of judder.
These issues are minor, but still annoying. (2 and 3) are likely related to the way Amazon Fire TV 3 handles refresh rate adjustment after the recent firmware update. Can you fix these in the next release of MrMC.
Thank you for the great software!
mirko1312
Re: Fire TV 3 question/problems with deinterlacing, playback starting paused
Post by mirko1312 » 12 Sep 2018, 06:02
Fire TV 3 owner here and can confirm issue no 3. playback always starts paused..very annoying please fix if you can.
Also after play/pause audio loses sync with auto framerate on.(not using audio passthrough, stereo audio)
As for issue no 1. Im aware that the problem is not in mrmc but amcodec not being supported on new Android versions but if you can reenable it in mrmc by some means that would be awesome.
clocks
Post by clocks » 13 Sep 2018, 02:45
I have same issues with the pendant. Videos usually start paused. And the audio gets so out of sync that I've had to start using Plex.
mirko1312
Post by mirko1312 » 17 Sep 2018, 17:26
Anybody from the dev team care to answer what the status of these issues is please(known, still trying to fix/fixed in testflight/will not be fixed for now).
Currently with the Fire TV Pendant with tgr new autoframerate supporting FW :
1.) the video is out of sync with/without passthrough using default MC Surface hw decoder when autoframerate is used(using only non-surface MC decoder fix this issue).
2.) Videos start paused
3.) Passthrough doesnt work for me (ancient DTS/DD receiver - firetv connected to TV, TV connected via spdif to audio receiver). Standard settings used in MrMC : output channels :2.0, passthrough enabled, checked DD/DTS and AC3 transcoding(tried without this also). Settings in FireTV: DD via HDMI. No sound!
Note: using this same settings in latest Kodi Krypton passthrough works OK with barely noticable few ms delay of audio/video sync (DD only though, no DTS).
Official Emby client works perfectly, outputs DD (still no DTS, but not important for me), perfect framerate, audio perfectly in sync.
The same audio out of sync issue(no 1) is also present in Kodi and in SPMC. Using non-surface HW fixes this issue.
Please if anyone from the dev team find some seconds to share their thoughts of this issues I would be very grateful.
Thank you
Post by koying » 17 Sep 2018, 18:48
There are so many changes coming in 3.7 that it's hard to relate to 3.6 issues.
3.7 should go out soon, please retest after you get the update.
mirko1312
Post by mirko1312 » 17 Sep 2018, 19:43
Ok, I will post my testing after update comes on amazon.
Thank you for answering. (and thank you very much for all the things you did for Kodi/SPMC)
Users browsing this forum: Bing [Bot] and 6 guests
