Major Audio Sync Issues
homestreamer1338
Post by homestreamer1338 » 09 Jul 2018, 19:20
To start, here is my setup:
Plex server on desktop, connected to router with ethernet.
Amazon FireTV Gen.2 using 5Ghz wireless.
FireTV --> HDMI --> Samsung MM55C 3.1 Soundbar --> HDMI --> TV
Pretty straightforward setup.
The audio sync issue I'm having is a new one, and one that I was not having when I initially purchased MrMC a month ago. The only thing that has changed in that time is that I've moved my Plex server from a laptop (using 5Ghz wireless) to a wired desktop.
I do not have this issue with the Plex client, or with Kodi.
I have this issue regardless of passthrough options. I have this issue after re-installing.
The issue was still present when I ran an ethernet to the FireTV, although it didn't seem as severe (maybe placebo).
Anyway, the audio sync is all over the place. Delayed, ahead, -.500ms, -.005ms, +.250ms, etc. A total, unusable mess.
Not only is the audio sync an issue when using MrMC, after I open and use MrMC the audio sync on my FireTV in general is messed up until I completely restart the device. This sync issue is also present on my FireTV pendant in my bedroom, so it isn't just the one device.
Any help with this issue would be greatly appreciated. I can provide more info if needed.
Re: Major Audio Sync Issues
Post by davilla » 09 Jul 2018, 19:24
homestreamer1338 wrote:
09 Jul 2018, 19:20
Something else is going on, there is no way an App can effect a/v sync for other Apps. Just does not work that way.
Debuglog please.
homestreamer1338
Post by homestreamer1338 » 10 Jul 2018, 18:15
09 Jul 2018, 19:24
Debuglog please.
Thanks for the prompt response!
I went ahead and factory reset my FireTV and that solved my problem.
Thank you for your work developing an excellent app.
