FTV Cube pausing immediatly after select/play
jccookii
Post by jccookii » 23 Jun 2018, 04:30
Ver. 3.6.2 on Fire TV Cube, any skin, default select action= play.
After selecting TV show or movie file, instead of immediately playing, it pauses. Clicking play on remote or selecting play from the menu will then resume play. Am I missing a setting (recient convert from Kodi, so not sure)?
Re: FTV Cube pausing immediatly after select/play
Post by amet » 23 Jun 2018, 04:58
Debuglog please
Post by davilla » 23 Jun 2018, 21:42
Looks like display switching is enabled. How long is the pause before resuming ?
jccookii
Post by jccookii » 23 Jun 2018, 21:49
It does not resume after pausing unless I intervene.
jccookii
Post by jccookii » 23 Jun 2018, 21:53
Turned off adjust display refresh rate, and issue is resolved.
Just for t-shooting purposes, the TV model is Samsung UN65K850D with software version T-JZMAKUC-1220.6,BT-S.
Set to 4K HDR+
Post by davilla » 24 Jun 2018, 02:06
23 Jun 2018, 21:42
^^ There's a setting for that.
HTPC-14
Post by HTPC-14 » 03 Jul 2018, 22:04
I have the same issue with my Firestick, with Refresh Rate switching enabled videos pause when playing and will only un-pause manually, I have tried adjusting with the pause before resuming setting but it didn't help
