TV shows are not being added to library
edgarcillo
Post by edgarcillo » 15 Mar 2018, 20:46
It may not be an issue with MrMC but the scrapper that is being used. I usually have all my TV show files added and ply using Plex but lately, I found voice/video sync issue quite often. Maybe my NAS (plex server) is having performance issues so I decide to use MrMC to organize them and play them, now with traktv i can have a better control. With this my problem started I noticed that my TV Shows were not getting update, I can see that a couple of them, a small amount, are added correctly but most of them are not. I checked name convention between the shows that are being added correctly and the shows that are not and everything is the same. If I go to section files I can see all fo them and play them but not from TV section. I have removed my NAs and added again and every time I update the library it takes a while and i can see all the files going through in the lower right corner but none of them get added. Does anyone know if there is a problem with the TV shows section? All my movies are added correctly the problem is just with the TV shows.
TrevorDanger
Re: TV shows are not being added to library
Post by TrevorDanger » 17 Mar 2018, 13:52
I'm also having this problem, but for both movies and TV shows. SMB connected, shares added, no scraping or appearing on the main screen. I can click through the file manager and the individual video files play back, but there is no metadata or anything. I'm assuming something's up with the scraper add-ons?
Post by davilla » 17 Mar 2018, 14:27
debuglog or no soup :)
TrevorDanger
Post by TrevorDanger » 18 Mar 2018, 02:05
https://pastebin.com/EvZmiXXN
I even uninstalled and reinstalled to see if that might fix the problem. No dice. Not sure why it's not locating the directories for scraping.
Post by davilla » 18 Mar 2018, 14:50
TrevorDanger wrote:
18 Mar 2018, 02:05
ERROR: CDSMSession: Auth failed, reason(-1073741710)
DEBUG: ------ Window Init (LockSettings.xml) ------
INFO: Loading skin file: LockSettings.xml, load type: KEEP_IN_MEMORY
DEBUG: CSettingsManager: requested setting (user.name) was not found.
DEBUG: CSettingsManager: requested setting (user.password) was not found.
DEBUG: CSettingsManager: requested setting (user.rememberpassword) was not found.
WARNING: Process directory 'smb://ROB-ACER/TV Shows/' does not exist - skipping scan.
It's not see them, can you see them as files ?
edgarcillo
Post by edgarcillo » 18 Mar 2018, 18:24
17 Mar 2018, 14:27
Hello Davilla.
here it is my log, sorry I forgot about it. https://pastebin.com/zw4WL4uY
I have to cut part of it because i guess i have a lot of info to scrap and was exceeding the limit to post but I ma sure I left enough for you to see if there is anything wrong. Some TV shows are scrapped correctly like The Flash, Taken, Ballers and SWAT so i know MrMc can access to my share drive and they have the same name convention that the rest that are not working. I will really appreciate any help. thanks.
TrevorDanger
Post by TrevorDanger » 18 Mar 2018, 18:27
18 Mar 2018, 14:50
TrevorDanger wrote:
18 Mar 2018, 02:05
Yes, I can see them and activate/play them.
TrevorDanger
Post by TrevorDanger » 20 Mar 2018, 22:21
MrMC is working as a front-end for Plex, so I'll just keep using that until/if I hear from you guys.
edgarcillo
Post by edgarcillo » 21 Mar 2018, 19:41
17 Mar 2018, 14:27
Hello davilla. have you had an opportunity to look at my log and see why the scrapper is not working properly for the TV Shows? I will really appreciate any help. thanks
TrevorDanger
Post by TrevorDanger » 31 Mar 2018, 08:57
Any resolution to this?
Users browsing this forum: Google [Bot] and 8 guests
