Proper de-interlacing settings for HDHomeRun Connect
sirmcftv
Post by sirmcftv » 22 Oct 2017, 22:21
I have a HDHomeRun Connect that just sends 1080i to the FireTV and by default it looks terrible. What are the proper settings in MrMC to get good quality de-interlacing?
If the FireTV cannot be made to look good with interlaced Live TV, is there a way to set up a backend PVR server that could take care of it and just feed proper 1080p to the FireTV? I could set up something like that on a powerful Linux server, I'm just not sure what a good server would be.
Re: Proper de-interlacing settings for HDHomeRun Connect
Post by davilla » 22 Oct 2017, 22:30
MediaCodec(surface) will automatically handle deinterlacing.
You can vector interlaced content to MediaCodec(non-surface) and then MrMC's deinterlacers handle it. The OSD video setting can be used to pick which flavor deinterlacer to use.
sirmcftv
Post by sirmcftv » 23 Oct 2017, 00:21
So I have to disable surface? Otherwise the de-interlace option is not available.
Post by davilla » 23 Oct 2017, 11:10
sirmcftv wrote:
23 Oct 2017, 00:21
no, just disable interlaced content for surface. The selection will fall through to next enabled decoder.
