Fire TV 2nd gen - multi channel PCM audio
sirmcftv
Post by sirmcftv » 02 Oct 2017, 14:11
My struggles with the Fire TV and multi channel PCM audio continue. Posted elsewhere here in the forums, I asked about the Fire TV 1st gen + Denon AVR-3808CI. @davilla has graciously looked at logs and I think the conclusion was there was something messed up in the Fire OS which resulted only in 2-channel PCM instead of multi-channel. The only way to make it work is to enable transcoding to DD.
Now I have another setup: Denon AVR-X2400H and Fire TV 2nd gen 4K. I tried playing a video with AAC 7.1 audio. The sound is a mess, all I get is 2 channels of garbled audio. In this case too, the way to get it to work is to enable transcoding to DD. What should my expectations be with this setup so I don't waste time trying various settings and losing my sanity in the process?
Re: Fire TV 2nd gen - multi channel PCM audio
Post by davilla » 02 Oct 2017, 15:26
On my Denon, multichannel works just fine, MrMC is set to 7.1 channels.
sirmcftv
Post by sirmcftv » 02 Oct 2017, 16:02
Great. Love it when it's my problem only :(
Which Denon do you have? Also, are you on the latest Fire TV 2nd gen OS update? Have you tried AAC 7.1? I think I read somewhere the Fire TV can't handle 7.1 well or at all, but I don't recall the entire scenario.
Post by davilla » 02 Oct 2017, 16:02
Also you might diddle with IEC setting, some amps want IEC on, some want it off.
Post by davilla » 02 Oct 2017, 16:04
Denon AVR-3200W and FireTV2 is running the latest update.
As for AAC 7.1, got a sample ?
