Album with single track not showing
mikehadfield
Post by mikehadfield » 07 Aug 2017, 12:12
In my library have have some albums which only have 1 track in them (for example concerts and audio books). When I go into the album it doesn't show the track - just the .. indicator.
If I go into a folder with 2 or more tracks then it is fine.
The official plex app works ok - it shows the single track.
Re: Album with single track not showing
Post by davilla » 07 Aug 2017, 15:17
sqlite (local) or mysql (remote) for library ?
mikehadfield
Post by mikehadfield » 07 Aug 2017, 15:55
Erm... not sure what you mean.
It accesses my plex server internally on the same network.
Post by davilla » 07 Aug 2017, 16:00
ok, you mean this is an issue with plex music then. We have four different ways to handle 'libraries', it helps to understand which one is having these issue :)
mikehadfield
Post by mikehadfield » 07 Aug 2017, 16:01
Yes, sorry. I should have made it clear this was a plex music library.
mikehadfield
Post by mikehadfield » 11 Aug 2017, 15:48
Any further update on this issue?
I am also running the 3.1.0 Testflight and it has the same issue. From a plex music library, if an album contains just a single track then it doesn't show the track when you click into the album. It just shows ".." instead. So at the moment it is not possible to play these albums in MrMC.
Post by davilla » 11 Aug 2017, 15:53
sorry, slipped through the cracks. I've created an issues for it.
https://github.com/MrMC/mrmc/issues/35
Post by davilla » 11 Aug 2017, 16:37
and fixed, will be in next testflight push
mikehadfield
Post by mikehadfield » 11 Aug 2017, 16:53
Brilliant. Many thanks.
