DTS passthrough with Gen 1 Fire TV
RobinWatts
Post by RobinWatts » 29 Jun 2017, 20:01
Hi all,
I have a Gen 1 Fire TV box, connected to a Yamaha RX-V377 surround amp (with 5.1 speakers) via an HDMI cable. The amp has DTS-HD and Dolby Digital True HD logos on it.
Background:
My DVD collection has overwhelmed the space available to it in my lounge, so I've decided to rip everything to a NAS and play it from there. I was using Kodi on the FireTV and it worked well for DVD rips, but I ran into a problem with getting surround sound playing from Blu-Ray rips. After a bit of googling, I found out about MrMC, and saw that it specifically allowed DTS passthrough - so I bought a copy.
Unfortunately, while there is a shiny "DTS capable reciever" option that I've turned on, I can't get DTS out.
The Problem:
I've ripped DVDs and BluRays to .mkv files on the server.
When I play a DVD stream back, it correctly plays surround sound. When I play a Bluray stream back, I just get stereo.
The settings:
MrMc: System - Settings: Audio output
Number of channels: 5.1
Output Configuration: Optimized
Stereo upmix: off
Maintain original volume on downmix: On
Boost Centre channel when downmixing: 0db
Resample quality: Medium
Threshold for pitch correction: 2
Keep audio device alive: 1 Minute
Level of inaudible silence: Default
(Greyed out: Support 8 channel DTS-HD audio decoding: Off)
Play GUI sounds: Only when playback is stopped
Enable Passthrough: On
Passthrough format is IES Packed: On
Dolby Digital (AC3) Capable receiver: On
Dolby Digital Plus (E-AC3) capable Receiver: On
DTS capable receiver: On
In the Amazon Fire Settings: Display and Sounds: I have Dolby Digital Output set to "Dolby Digital Plus over HDMI".
The Bluray rip I'm trying to test has a DTS-HD 5.1 audio stream, with a DTS 5.1 'core' audio stream.
While the file is playing, if I press the burger button on the remote, I get some file information pop up:
D(Audio: truehd, 48000 Hz, 5.1(side), s32 (24 bit)
P(aq:99%, Kb/s:3345.79, att:0.0 dB)
D(Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9])
P(vq:99%, Mb/s29.39, fr: 23.976, dc:amc-h264(S), drop:0, skip:0, pc:none)
(and some CPU usage stuff which I've omitted).
My surround amp clearly shows I'm only getting 2 channels sent though.
Can anyone tell me what I'm doing wrong please? Should this work? Do I need to rip the Blurays differently?
Thanks in advance for any advice people can give!
Robin
Re: DTS passthrough with Gen 1 Fire TV
Post by amet » 29 Jun 2017, 20:38
hi,
could you also get us a file mediainfo and debuglog while the file is playing
thanks
RobinWatts
Post by RobinWatts » 29 Jun 2017, 21:15
Ok, embarassing confession time...
"could you also get us a file mediainfo and debuglog while the file is playing"
I'm not sure how to do this, but in trying I've spotted something. If I click the middle button on the remote, it says:
[1080] [Dolby True HD] [5.1] [eng]
So it looks like this is a Dolby True HD stream, not a DTS-HD one. My apologies.
Having just tried a different BluRay with a DTS-HD Master Audio track, and that plays fine.
Going back to the problem file, I found the "Audio and Subtitle Settings" page, and the stream that is coming out as stereo says "English - Surround 5.1 - Dolby TrueHD 5.1 (1/3)". If I change that to "English - Surround 5.1 - AC3 5.1 (2/3)", I get 5.1 sound out. Woo Hoo!
So, we now have 3 questions:
1) Should I be able to play a Dolby True HD stream ? Can that be passthrough'd ?
2) How do I get a file mediainfo?
3) How do I get a debuglog while the file is playing?
Thanks again.
Post by davilla » 29 Jun 2017, 22:34
RobinWatts wrote:
29 Jun 2017, 21:15
1) No, that would require a sample rate of 192KHz and the FireTV1/2 cannot be configured for sample rates above 96KHz.
2) See the how mediainfo is sort of highlighted ? Click on it :)
3) Same for debuglog
RobinWatts
Post by RobinWatts » 29 Jun 2017, 22:45
29 Jun 2017, 22:34
1) Ah, well that makes perfect sense then. I'll try reripping that disc with just the non HD 5.1 selected.
2) D'Oh. I'd looked at the link, saw that it went off-site and figured that it was one of those annoying bulletin board things that 'helpfully' highlights words. What a fool.
3) yeah, a complete fool.
So, in light of 1), I consider this problem solved, and there seems little point in wasting your time with 2) and 3). Thanks for your help!
