Audio out of sync
pattyland
Audio out of sync
Post by pattyland » 19 Apr 2017, 08:29
Hi there!
I just bought MrMC because SPMC startet to stutter on my Fire TV Stick when playing 1080p files since I was upgraded to Fire OS 5.2.4.1.
MrMC plays the video pretty smooth, but the Audio ist out of sync a few seconds after watching a few seconds. I use audio passthrough if this important!
Greets, pattyland
Re: Audio out of sync
Post by davilla » 19 Apr 2017, 11:56
5.2.4.1 seems to be causing some issues. Not only with MrMC but with SPMC and Kodi. Looking into it.
DMC_12
Post by DMC_12 » 19 Apr 2017, 12:12
At least Amazon let him install the App. :lol:
pattyland
Post by pattyland » 07 May 2017, 21:12
Just updated to MrMC 3.0.3, audio is still out of sync after a few seconds :(
After about 30 seconds it stopped for half a second, I see the little playbar in the top right corner, and the sound is synced for a few seconds... This repeats all the time
Any update on this?
Post by amet » 08 May 2017, 03:29
Let's see a debuglog please when this is happening
pattyland
Post by pattyland » 08 May 2017, 05:33
Ok, here it is: https://pastebin.com/U0zCeHrD
Just be sure, I could play this file fine before Fire OS 5 with SMPC. The problems started after the update...
Post by davilla » 08 May 2017, 12:20
pattyland wrote:
08 May 2017, 05:33
Are you running with adjust display ? That is broken with the Amazon update, there is nothing we can do to fix it.
pattyland
Post by pattyland » 08 May 2017, 15:31
I really don't changed anything in the MrMC options beside passthrough audio output. Or is this an option for the Fire OS?
Can somebody unsolve this thread? I added it accidentally :(
pattyland
Post by pattyland » 09 May 2017, 21:05
I got this, you mean "Calibrate Display", right? Yes, I has this enabled at 3%. I disabled it, and the sound was perfectly synced with the video. Even SMPC can play the videos without stuttering anymore!
Downside: I loose a few pixels at every side now... :?
Post by cosmoxl » 09 May 2017, 21:26
pattyland wrote:
09 May 2017, 21:05
Do you have a setting on your TV that can remove that overscan? If so, that's where the change should be made.
