[FIXED]Just bought MrMC , says not compatible with FireTV
DMC_12
Post by DMC_12 » 17 Apr 2017, 13:00
Fix: Factory Reset
I bought MrMC from Amazon on my computer and while it shows my old FireTV Stick it says my FireTV is not compatible with this app.
Turned up the fire tv and searched for MrMC. It shows again the app with price to purchase. I clicked on purchase and it said that it is not compatible, then the buy button changed to "already owned".
I am confused. I thought this app is for FireTV ?
Re: Just bought MrMC , says not compatible with FireTV
Post by cosmoxl » 17 Apr 2017, 13:16
DMC_12 wrote:
17 Apr 2017, 13:00
yes, it is. I hope this works out for you. Sounds like a glitch with Amazon or something.
DMC_12
Post by DMC_12 » 17 Apr 2017, 13:49
cosmoxl wrote:
17 Apr 2017, 13:16
alright thanks. I will have to write to the support then.
Maybe it is because of the new FireTV OS.
DMC_12
Post by DMC_12 » 29 Apr 2017, 11:35
Since Amazon couldn't help me , I managed to fixed it. The update seems to bork a lot of things. So after updating you should do a factory reset on the device to fix incompatible app issues.
