Help with playlists
PeteHH
Help with playlists
Post by PeteHH » 11 Jan 2019, 08:26
Hi all.
I'm a new user with MrMC, so I hope that I'm not just dumb enough to find the solution myself. I have the Lite version so far on Apple TV 4, and I cannot find a way to play an existing music playlist. I save the playlist in the root folder on my NAS and also in a separate folder, but it doesn't appear anywhere. And when I go to the playlist function I can only create a new one or a new intelligent one, but I want to use existing m3u files I have already created.
Can you help please? Is that a Pro function. I will upgrade anway because I like the app, but only if the playlist can besolved for me.
Kind regards
Re: Help with playlists
Post by amet » 11 Jan 2019, 11:50
Just add a source ( folder where your playlist is) using Media Source -> music button on home, access that folder and play the list
