Play next video automatically w/ plex integration
erice02o
Post by erice02o » 30 Nov 2018, 05:37
Title pretty much says it. I have the play next video automatically enabled in MrMC settings, but they don’t play if they are plex fed. It works if the videos are from a network shared folder, but I prefer plex backend. Is there any plan to enable this?
Re: Play next video automatically w/ plex integration
Post by davilla » 30 Nov 2018, 18:50
erice02o wrote:
30 Nov 2018, 05:37
plex client or plex extension ?
erice02o
Post by erice02o » 30 Nov 2018, 18:54
Sorry, Plex extension
Post by davilla » 30 Nov 2018, 20:14
Plex extension is independent of core handling. There are no plans to extend core settings into extensions. Use the internal plex client if you want core integration.
erice02o
Post by erice02o » 03 Dec 2018, 03:52
Pardon me, upon looking at it again, I realized I was talking about the plex client. My bad. I don’t use the extension.
So yes, using the plex client, the next video doesn’t auto play. And it isn’t just on the Apple TV, I’ve tested it on the firetv as well, and it has the same behaviour.
Post by amet » 03 Dec 2018, 14:32
should be fixed for next 3.7.1 TestFlight, if you are enrolled.
Users browsing this forum: sm0ke83 and 7 guests
