sudden Strange Behavior from remote, work around found.
metaman
Post by metaman » 15 Oct 2018, 04:51
First of all, if this has come up I apologize I didn't see anything matching my problem.
Basically, I can play anything that is in my library (ie, movies and shows that have metadata) I cannot seem to play videos that don't have data, our video files, random movies files. etc.
the file type does not matter
there's nothing funky in the names.
I connect to MrMC a couple ways, I use a siri remote and the kore kodi remote ios app.
all our movies are stored on a NAS.
we have an apple tv 4, been running for a long time.
Everything's been working perfectly, until this evening while my son was messing around with the kore ios app, using the "remote control" (screen with up down left right, next track , play pause etc). when all of a sudden the video he wanted wouldn't play. you could see the cursor flash and click, but the file wouldn't play. ok so now, I cant play a movie file that isnt from the tvdb and tmdb world, this occurs on both the kore remote and the siri remote.
So I tried rebooting the NAS, removing and reinstalling MrMC. didnt fix the problem.
I found something odd after reinstalling. when I access a folder for the first time, I can play a video, but just the 1st time. then it just "clicks" and does nothing. I found I can play any video if I hold select button until the context menu comes up and choose "play from this location" the file would play but obviously this isn't practical. any file that shows up in my library, tv shows and movies behaves normally.
thanks for reading, thanks for any help
Meta
Re: sudden Strange Behavior from remote
Post by davilla » 15 Oct 2018, 11:37
debuglog please
metaman
Post by metaman » 18 Oct 2018, 14:49
Post by amet » 18 Oct 2018, 16:35
Feel like getting into TestFlight? Some of it might be fixed
viewtopic.php?f=10&t=4494
If TestFlight doesn’t fix it for you, see below
Issue is with the setting for “select”, Siri pad click. Default behavior is now changed to info and that obviously doesn’t work well on non library items.
Settings -> videos-> filelists -> default select and change it from info to play
metaman
Post by metaman » 18 Oct 2018, 17:14
If its easy enough to install on TvOS , sure.
but Id like to point out this setup worked for months and months and even just a minute before the problems started occurring.. ,
My son was messing with the KORE app on an iphone controlling MrMC on TvOS, id like to note that since connecting to the reinstall of MrMC my connection on the hosts screen is yellow instead of green.. I imagine its all related.
Anyway to fix my all vanilla setup of MrMC? I guess I could do a factory restore of the apple TV 4 and see if that fixes it..
thanks
metaman
Post by metaman » 18 Oct 2018, 22:05
So I just did a full system reset.
Videos seem to play, just in case mrmc doesnt like the folder location, I moved my folder of random video files out of my tv series parent folder.
Pretty painless work around, if a fix isn't easy. I'd call it solved, until my son figures out how to break it again.
Thanks for the help.
Metaman
