wifi streaming
notlbishop
wifi streaming
Post by notlbishop » 05 Oct 2018, 19:18
hi, having a few issues streaming HEVC over wifi even though everything suggests it should be possible.
appletv speedtest app shows 350mbps download which is my external internet speed
i have tried serving the files from multiple sources over SMB and NFS and all served over gigabit ethernet. transferring files to and from these sources using a laptop are all above required speeds (30-70MB/s)
so this shows the files i'm streaming which go up to 70mbps should be able to be streamed over wifi shouldn't they?
Spindel
Re: wifi streaming
Post by Spindel » 05 Oct 2018, 20:22
70 MB/s is 560 mbps (meaning more than 350 mbps).
But I suspect the issue lies more with your home network than MrMC.
Do you have the possibility to move your ATV closer to the router (or AP) just to test and see if that solves your problem?
notlbishop
Re: wifi streaming
Post by notlbishop » 05 Oct 2018, 23:46
no no there's no video file encoded at 70MB/s :)
the video files are around 70mb/s. i can transfer to and from these sources at 70MB/s. the atv has shown it can download externally at 350mb/s so would expect internally to be even faster but it isn't but can't see a reason why that is..
