3.7.0 - Resume doesn't work  [SOLVED]
mett-eagle
Post by mett-eagle » 25 Sep 2018, 13:58
i'm using 3.7.0 on a AppleTV 4k and a central MySQL database for the watched state. Up till 3.6.x resume worked fine, since 3.7.0 MrMC every video starts from the beginning, regardless the watched state.
Do i need to change something in the database? All my other clients (FTMC on FireTV) work fine with these watched states in the database.
Thanks for your help,
Martin
Re: 3.7.0 - Resume doesn't work
Post by amet » 25 Sep 2018, 15:29
this is really strange, and it has been reported earlier but no one can give me a straight answer on how they are playing these files...
are you using "Play" on apple tv remote to play? or are you using select to go into video info and hitting play button in there?
I cannot reproduce this issue on my apple tv and mysql central database... its driving me insane :(
mett-eagle
Post by mett-eagle » 25 Sep 2018, 15:44
i‘m going into videos and use the select button (press the touch pad on top) on the file. i‘ve never used the play/pause button, but that works. the select button worked in 3.6.
Post by amet » 25 Sep 2018, 18:02
just to be clear, you have changed how select works? default action for select is to show info
Golge77
Post by Golge77 » 25 Sep 2018, 18:23
I have this "issue" aswell.
Using my harmony with same programming as before 3.7 and now resume doesn't work.
Is it possible to change some setting in 3.7 to get "select" back as in 3.6
mett-eagle
Post by mett-eagle » 25 Sep 2018, 18:54
25 Sep 2018, 18:02
i‘ve checked my config, but i honestly don‘t remember, i‘m sorry.
Re: 3.7.0 - Resume doesn't work  [SOLVED]
Post by amet » 25 Sep 2018, 19:34
Golge77 wrote:
25 Sep 2018, 18:23
Settings -> videos -> file lists -> default select action
Golge77
Post by Golge77 » 25 Sep 2018, 20:00
25 Sep 2018, 19:34
Golge77 wrote:
25 Sep 2018, 18:23
Thank you!
mett-eagle
Post by mett-eagle » 26 Sep 2018, 06:41
25 Sep 2018, 19:34
Golge77 wrote:
25 Sep 2018, 18:23
Thanks, setting that to Play worked.
Users browsing this forum: Google [Bot] and 11 guests
