Hello,
I want to try MrMC if it can be my new IPTV Client on my ATV 4K, so I downloaded the free Lite Version.
As I have a lot of experience with Simple Client on KODI at my different Fire TV devices, there where no problems in enabling it and adding the remote URLs for m3u, EPG and Logos.
It was not loading any channels, so I changed some settings to force a reload, but noting happened.
Then finally when I disabled the Simple Client, MrMC was instantly scanning for channels and found, of course, nothing. And then I got the error message like: No TV Add-on enabled.
Is this function not testable with the Lite version? Or is it a bug, that MrMC JUST scans for TV channels, after the Add-on is DISABLED? I reinstalled MrMC three times now and my problem is reproducible.
Simpe IPTV Client with MrMC Lite
Re: Simpe IPTV Client with MrMC Lite
Lite version is fully functional, except it lists only 8 items...
There could be a delay in loading the remote m3u8 list for some reason... debuglog would show the issue but Lite version has webserver disabled so you can’t pull it
I use m3u8 list locally ( on my qnap) and remotely with /get.php?username=***&password=*** setup and both work just fine
It’s intended to work just as you think it was, enable simple IPTV addon, enable TV and it should just pull channels.
Users browsing this forum: No registered users and 10 guests
