3.7 and plex (and a question about opacity)
Spindel
Post by Spindel » 18 Sep 2018, 18:16
I can’t get this version to load my plex library at all.
I can reach it trough media sources UPnP-sources but it does’t load up the homeshelf like it did before. And the UPnP method is kind of cumbersome and requres a lot of diving into menus.
Also I tried Opacity in 3.7 (because I liked it) and as soon as you go to the home screen you are stuck and can’t navigate anywhere with the appleTV remote.
Spindel
Re: 3.7 and plex (and a question about opacity)
Post by Spindel » 18 Sep 2018, 18:32
Ok update.
Niether the plex client nor the plex extension can connect to my plex server.
Post by timstephens24 » 18 Sep 2018, 20:50
Weird, I'm connecting to Plex fine and did a complete reinstall on the last TestFlight build to test out that it connected to Emby, Plex, and MySQL fine (it did).
Spindel
Post by Spindel » 19 Sep 2018, 05:28
I’ve now testet both on my atv4 and 4k and works on niether.
Either I’m stupid (not entierly out of the question) or there is an issue with the latest release.
EDIT:// as a bonus I can also say I have the same issue with my iPhone installation
Spindel
Post by Spindel » 19 Sep 2018, 13:05
Ok so my mrmc install on my iPad does not work either with 3.7.
There is two options:
Plex in 3.7 is broken.
Or
Something between my plex server install and 3.7 has a conflict (I’m running the server on a synology diskstation).
Pre 3.7 MrMC and plex worked without flaw on all my devices.
Post by amet » 19 Sep 2018, 23:51
Is plex server selected on home screen?
Spindel
Post by Spindel » 20 Sep 2018, 04:11
I can’t select it because all my installations only find mrmc server
Post by amet » 20 Sep 2018, 04:38
Debuglog please
Spindel
Post by Spindel » 20 Sep 2018, 08:54
20 Sep 2018, 04:38
Debuglog please
Log from my ATV4K here:
https://pastebin.com/i0qGrY77
I tried the official Plex app for the ATV4K and it has no problems connecting to the server.
Schweppy
Post by Schweppy » 20 Sep 2018, 11:07
Also thought I had this issue but since upgrading to 3.7 it now takes 30-40 seconds to show my Plex library on home screen where as pre update is was less than 5 seconds.
