I'm new here. If i do something wrong, please let me know.
I'm having a problem with audio at somefiles. Sometimes it does no play it the main stream, it just plays the "background" sound, even If i change language, it does not play the new language, but other times it plays it normally, and other players play it. So I don't think it is the file.
Passthrough in MrMc currently off
I tried rebooting apple tv, start MrMC as first app, then play one of the files with the problem (Jack Ryan), and got the error, then I played other file I don't have the problem (Westworld), it started without the main audio, but it quickly correct itself, and started playing the main audio, I got back to the first file, and then It played the main audio.
Full log:
https://pastebin.com/yRH3pN2k
Two more doubds:
1) How can I capture screen of one movie at tvos?
2) is there anyway to see live info about the file playing (FPS, bitrate, codec)? How?
Regards,
Audio not playing
Re: Audio not playing
1) you need Xcode to capture screen on tvOS
2) you can do it via web server -> https://wiki.mrmc.tv/index.php?title=Codec_Info
- timstephens24
For 2, if you want to see the information on the TV you can run this command from a computer (just replace the IP [1.2.3.4] with your Apple TV IP)
curl -X POST -H "Content-Type: application/json" -d '{"jsonrpc":"2.0","method":"Input.ShowCodec","id":1}' http://1.2.3.4:8080/jsonrpc
