Library updates  [SOLVED]
azriel84
Library updates
Post by azriel84 » 20 Aug 2018, 08:01
Lately I've been updating my library with 4K HDR versions of the movies I already have @ 1080p. NFO details are updated for each movie etc but when I run update library the metadata info remain the same unless I run the movie and "force" the app to apply the new metadata. Is this an issue or smt normal for changed files?
Re: Library updates  [SOLVED]
Post by amet » 21 Aug 2018, 22:25
its normal, you need to clean and update the library to remove old video from it and add the new one
azriel84
Re: Library updates
Post by azriel84 » 22 Aug 2018, 06:02
Great, thanks!
Users browsing this forum: No registered users and 11 guests
