When you hit the pause button, I used to see an OSD / menu at the bottom, which was quite functional and easy to use
But, in the last few months, with one of the updates, something has happened, and now I am not seeing the bottom section at all, but just the pause info at the top, and when I click on DOWN arrow, I can see Subtitles, Settings, and this one is quite hard to use:
Every once in a while, you can see the section at the bottom when you hit pause, but it is almost random.
Can you pleasee tell how I can get the OSD at the bottom and use that again?
Thanks a ton!
On Screen Display after Pausing
Re: On Screen Display after Pausing
enable siri expert mode
