I‘ve tried MrMC with Tvheadend plugin and live tv. Whenever I start a HD program it‘s getting decoded on the CPU but not on HW. I‘ve activated HW Acceleration in the options but it‘s not working anyways.
Anybody knows why?
Thanks in advance!
Apple TV 4k -HW Acceleration LiveTV
Re: Apple TV 4k -HW Acceleration LiveTV
The hardware on the apple tv doesn't handle mpeg2 or interlaced material (even if it's h264). So, that covers a lot of the broadcast TV standards.
Are you having problems?
Thanks for you answer!
Oh :/ Does it handle mpeg2 oder h264 if it‘s not interlanced?
I haven‘t problems, but isn‘t CPU usage on 200% not on it‘s limit?
Best regards
Hardware decode doesn't handle mpeg2 and it doesn't handle interlaced, no matter the codec. Of course, it handles progressive h264 and h265. However, MrMC is probably coded such that playback within the DVR extension will always use ffmpeg.mm5533 wrote: ↑24 May 2018, 17:09Thanks for you answer!
Best regards
The deinterlacing is what pushes up the CPU usage but for the ATV4k the max is 400% (as you go by what MrMC reports) as it has 4 cores. On the older ATV4 200% would be the max because it has 2 cores.
Oh okay! Thanks the information!cosmoxl wrote: ↑24 May 2018, 17:12Hardware decode doesn't handle mpeg2 and it doesn't handle interlaced, no matter the codec. Of course, it handles progressive h264 and h265. However, MrMC is probably coded such that playback within the DVR extension will always use ffmpeg.
4 cores? I thought I were 3?
Maybe I'm remembering wrong. I thought it had 2 fast and 2 "slow". But, I see other talk of 6 cores, and another site that does say 3 for the CPU - not counting the GPU. So,mm5533 wrote: ↑24 May 2018, 17:17Oh okay! Thanks the information!cosmoxl wrote: ↑24 May 2018, 17:12Hardware decode doesn't handle mpeg2 and it doesn't handle interlaced, no matter the codec. Of course, it handles progressive h264 and h265. However, MrMC is probably coded such that playback within the DVR extension will always use ffmpeg.
3 cores, see debuglog. it does not lie
