Keyboard support for Apple TV
solamnic
Post by solamnic » 16 May 2018, 14:00
I can connect a bluetooth keyboard in my Apple TV 4k.
Running Mrmc i can move thru movies using arrow keys but which key to press to simulate the remote's long press (so i can bring up menu?)
2) is there a way to avert MrMc from going to the main Apple TV menu when pressing the back key? (no exit from MrMC using back key in remote)
3) MrMC keeps library movie thumbnails locally?
Thank you
Keep up the great work
Re: Keyboard support for Apple TV
Post by davilla » 16 May 2018, 15:01
just got a replacement apple keyboard, so 1) will check
2) Apple requires all apps to return to tvOS home when back is pressed at app home. Grounds for instant review reject if the app does not do this.
3) Depends on how you have things setup. Generally there are local cache of thumbs but there are ways to have thumbs on servers.
solamnic
Post by solamnic » 16 May 2018, 15:57
1) Please post your findings on keyboard with apple tv :)
2) Too bad :)
3) Have the 64gb i just want everything to be stored locally :)
solamnic
Post by solamnic » 18 May 2018, 19:21
@davilla
Have you tried the keyboard?
Have you found the key to display the "long key" press menu?
solamnic
Post by solamnic » 01 Jun 2018, 16:14
Today i got a Bluetooth Keyboard to test with my appletv 4k.
Long press is achievable by long pressing the enter key.
I run the keymap editor and i found out that in Navigation Menu is mapped under c and Movie info under d,
Pressing those keys while browsing a movie do nothing...
Any ideas?
solamnic
Post by solamnic » 05 Jun 2018, 12:07
Tested ver 180603.2257 @20180603-14ddd99..
Keyboard issue not fixed.
Post by davilla » 05 Jun 2018, 13:44
keep in mind that just because you can connect a keyboard to the appletv does not mean that all keys work. TVOS is not designed for general keyboard usage and in fact, the general keyboard iOS APIs are forbidden and will result in app rejection during review if present.
solamnic
Post by solamnic » 05 Jun 2018, 17:26
05 Jun 2018, 13:44
I see... :)
Post by davilla » 13 Jun 2018, 03:01
fixed in upcoming testflight push for v3.7.0
