This has probably been discussed many times but I bring it up again since both apps now have really good Plex integration.
Is upscaling etc. better with MrMc?
MrMc vs Infuse - picture quality
Re: MrMc vs Infuse - picture quality
I suspect they are similar right now but once we bring in the advanced upscalers, MrMC will be much better.
Possible next version turn. Several things are under construction.
for droid, yes. shaders need work for iOS/tvOS. They depend on EGLImage which is not present under iOS/tvOS.
Don't mean to bug you @davilla but any update on this? The current upscaling on the ATV4k is just not as good as my TVs upscaler so I'm looking forward to a good upscaling algorithm. Even infuse doesn't support this yet
Test builds for Shield with high quality scalers are available.semperfixd wrote: ↑09 May 2018, 18:27Don't mean to bug you davilla but any update on this? The current upscaling is just not as good as my TVs upscaler so I'm looking forward to a good upscaling algorithm. Even infuse doesn't support this yet
Just follow along in the testflight thread to see the progress. Or ask to get the test builds yourself.
