resolution output managed by MrMc ?
costaud
Post by costaud » 16 Apr 2018, 13:29
Hello,
Do you think it will be possible to play 1080p or 4K files at their own resolution on MrMc ?
Regardless of Apple TV resolution setting ( UHD for example to play netflix .... in 4K) , if we play a 1080p on MrMc, output will be 1080p ( upscaling will be done by 4K TV with clearness used to improove quality picture and not by the ATV) , if we play 4K file, output will be 4K resolution.
I ask that because on Shield TV using KODI we can do that and it will be great to have same thing with ATV 4K ;)
You can ask to koying, if we put kodi settings to 1080p (shield TV resolution to 4K) , 1080p files will be played in 1080p and 4K file in 4K ;)
Re: resolution output managed by MrMc ?
Post by davilla » 16 Apr 2018, 17:35
No, we are not in control of the actual display on the AppleTV 4/4K, all we can do is request a resolution/rate. How that is implemented it up to tvOS.
costaud
Post by costaud » 17 Apr 2018, 12:03
OK, thanks for the answer ;)
user1001
Post by user1001 » 24 Apr 2018, 00:00
If only we could have this and ATMOS!
Users browsing this forum: Google [Bot] and 4 guests
