Passthrough issue
Oscar_206
Passthrough issue
Post by Oscar_206 » 30 Mar 2018, 10:20
Unfortunately i have a Problem with passthrough after the latest Update.. iam Not shure if the reason is the atv update or the mrmc update.
When iam using passthrough, only a ugly noice comes out of my speakers. Before the updates everything was fine with dts and Dolby. Do you allready know the issue?
Iam on the Atv 11.3 and mrmc v 3.6.0. I tried it several times but its allways the same. As i said, before the updates everything works correct.
My av Receiver dont change the input audio to dts or dolby when i start the movie.. only when passthrough is turned off, stereo is coming out fine.
Hope there will be a fast solution..
eazytv
Re: Passthrough issue
Post by eazytv » 30 Mar 2018, 10:44
Known issue in 11.3 since beta testing. :?
Post by amet » 30 Mar 2018, 10:53
try to disable passthrough in settings -> system-> audio output and see if that helps
haffi@haffi.is
Post by haffi@haffi.is » 30 Mar 2018, 11:59
same problem , its related to DTS pass through it seams.
I wonder how much cpu it takes to decode 5.1 DD or DTS to PCM and send it down. ?
Will it be a problem ?
If not then this should work fine and deliver the best audio possible ( but at a cost of cpu on apple tv )
Post by amet » 30 Mar 2018, 12:05
Shouldn’t take too much, I think we can reproduce the issue now and will be looking at a fix ASAP... 3.6.1 to TvOS will follow soon
haffi@haffi.is
Post by haffi@haffi.is » 30 Mar 2018, 12:25
ok I tried ac3 also , but it also does not work within MRMC.
Doing test to see if it works on NEtflix or Plex Native client.
haffi@haffi.is
Post by haffi@haffi.is » 30 Mar 2018, 14:10
Netflix and Plex use PCM audio, when they are sending it. Wether its 5.1 DD or DTS from their movies. It just sends PCM
Post by davilla » 30 Mar 2018, 14:13
Make sure that tvOS audio settings did not get reset to default, this happens sometimes when a tvOS update is released.
Oscar_206
Post by Oscar_206 » 30 Mar 2018, 18:03
What do you mean by default? There are only 3 Settings - Stereo, Dolby or best Audio (lpcm)?
Oscar_206
Post by Oscar_206 » 30 Mar 2018, 18:04
haffi@haffi.is wrote:
30 Mar 2018, 14:10
If you set up Dolby in atv Settings, Netflix will also have Dolby, no pcm
