Can't see files in Plex library...
brian@guzanet.com
Post by brian@guzanet.com » 11 Mar 2018, 17:54
Hi. I have a small test Plex library. It has only one show in it, with 3 episodes. It is in a plex-friendly directory structure.
If I look at this library in Plex or in Infuse, I see the three episodes. If I look at this library in MrMc (either IOS or Apple TV), it appears that there is nothing in the library. I made sure that there were no filters on the library and that Hide Watched is not set.
Any ideas what might be causing this and how I can diagnose this disappearance?
thanks
BrianGGG
Re: Can't see files in Plex library...
Post by davilla » 11 Mar 2018, 18:12
debuglog
and describe exactly the directory structure
brian@guzanet.com
Post by brian@guzanet.com » 13 Mar 2018, 15:10
Thanks. Exact file structure for library in question (called ZZZ Test in Plex and pointing to the ZZZTest parent directory) is:
 Directory of H:\Videos\ZZZTest\The Affair\Season 01
11-Mar-18  07:53 PM    <DIR>          .
11-Mar-18  07:53 PM    <DIR>          ..
12-Feb-18  04:26 PM     1,457,429,369 The Affair - S01E01-1.mp4
12-Feb-18  08:08 AM     1,301,211,808 The Affair - S01E02-2.mp4
12-Feb-18  09:01 AM     1,320,745,508 The Affair - S01E03-3.mp4
12-Feb-18  05:22 PM     1,386,973,294 The Affair - s01e04 - 104.mp4
09-Mar-18  08:57 AM                33 The Affair-S01E01-1.edl
               5 File(s)  5,466,360,012 bytes
               2 Dir(s)  664,707,493,888 bytes free
Debug Log is:
Content of MrMC Log
10:56:33 T:6169374720  NOTICE: special://profile/ is mapped to: special://masterprofile/
10:56:33 T:6169374720  NOTICE: -----------------------------------------------------------------------
10:56:33 T:6169374720  NOTICE: Starting MrMC (3.5-0 Git:2018-02-11-e4b5e59). Platform: iOS ARM64 64-bit
10:56:33 T:6169374720  NOTICE: Using Release MrMC x64 build
10:56:33 T:6169374720  NOTICE: MrMC compiled Feb 11 2018 by Clang 9.0.0 (clang-900.0.39.2) for iOS ARM64 64-bit version 10.2.0 (100200)
10:56:33 T:6169374720  NOTICE: Running on Apple Inc. iPad4,7 with iOS 11.2.6, kernel: Darwin ARM 64-bit version 17.4.0
10:56:33 T:6169374720  NOTICE: Host CPU: arm64 v8, 2 cores available
10:56:33 T:6169374720  NOTICE: ARM Features: Neon enabled
10:56:33 T:6169374720  NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome
10:56:33 T:6169374720  NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome
10:56:33 T:6169374720  NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/0090BCA9-1676-4B85-A18F-84CC95F89F58/Documents/MrMC/userdata
10:56:33 T:6169374720  NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/0090BCA9-1676-4B85-A18F-84CC95F89F58/Documents/MrMC
10:56:33 T:6169374720  NOTICE: special://temp/ is mapped to: /var/mobile/Containers/Data/Application/0090BCA9-1676-4B85-A18F-84CC95F89F58/Documents/MrMC/temp
10:56:33 T:6169374720  NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/0090BCA9-1676-4B85-A18F-84CC95F89F58/Documents/MrMC/logs/
10:56:33 T:6169374720  NOTICE: special://frameworks/ is mapped to: /var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/Frameworks
10:56:33 T:6169374720  NOTICE: The executable running is: /var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/MrMC
10:56:33 T:6169374720  NOTICE: Local hostname: BRIANs-iPad-mini
10:56:33 T:6169374720  NOTICE: Log File is located: special://logs/mrmc.log
10:56:33 T:6169374720  NOTICE: load settings...
10:56:33 T:6169374720 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
10:56:33 T:6169374720 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
10:56:33 T:6169374720 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
10:56:33 T:6169374720  NOTICE: Found 1 Lists of Devices
10:56:33 T:6169374720  NOTICE: Enumerated DARWINIOS devices:
10:56:33 T:6169374720  NOTICE:     Device 1
10:56:33 T:6169374720  NOTICE:         m_deviceName      : default
10:56:33 T:6169374720  NOTICE:         m_displayName     : Default
10:56:33 T:6169374720  NOTICE:         m_displayNameExtra:
10:56:33 T:6169374720  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
10:56:33 T:6169374720  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
10:56:33 T:6169374720  NOTICE:         m_sampleRates     : 44100,48000
10:56:33 T:6169374720  NOTICE:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
10:56:33 T:6169374720  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
10:56:33 T:6169374720  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:56:33 T:6169374720  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:56:33 T:6169374720  NOTICE: Default DVD Player: dvdplayer
10:56:33 T:6169374720  NOTICE: Default Video Player: dvdplayer
10:56:33 T:6169374720  NOTICE: Default Audio Player: paplayer
10:56:33 T:6169374720  NOTICE: Enabled debug logging due to GUI setting (2)
10:56:33 T:6169374720  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
10:56:33 T:6169374720  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:56:33 T:6169374720   ERROR: CMediaSourceSettings: error loading special://masterprofile/sources.xml: Line 0, Failed to open file
10:56:33 T:6169374720  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:56:33 T:6169374720   DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
10:56:33 T:6169374720   DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
10:56:33 T:6169374720   DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: M4V
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
10:56:33 T:6169374720   DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
10:56:33 T:6169374720  NOTICE: Loaded playercorefactory configuration
10:56:33 T:6169374720  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:56:33 T:6169374720  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:56:33 T:6169374720    INFO: creating subdirectories
10:56:33 T:6169374720    INFO: userdata folder: special://masterprofile/
10:56:33 T:6169374720    INFO: recording folder:
10:56:33 T:6169374720    INFO: screenshots folder:
10:56:33 T:6171095040    INFO: CActiveAESink::OpenSink - initialize sink
10:56:33 T:6171095040   DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
10:56:33 T:6171095040   DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz) pcm
10:56:33 T:6171095040  NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
10:56:33 T:6171095040  NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 44100.000000
10:56:33 T:6171095040  NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.023220
10:56:34 T:6172241920   DEBUG: CPlexServices::Process bgn
10:56:34 T:6171095040  NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.065545
10:56:34 T:6171095040  NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
10:56:34 T:6171095040  NOTICE: void dumpAVAudioSessionProperties() audio route = Speaker
10:56:34 T:6171095040  NOTICE: void dumpAVAudioSessionProperties() sampleRate 44100.000000
10:56:34 T:6171095040  NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.018730
10:56:34 T:6171095040  NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.023220
10:56:34 T:6171095040  NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
10:56:34 T:6171095040  NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: input count = 1
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: portName, iPad Microphone
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: channelLabel, 0
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: channelName , iPad Microphone
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: output count = 1
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions : portName, Speaker
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: channelLabel, -1
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: channelName , Speaker 1
10:56:34 T:6171095040   DEBUG: DumpAudioDescriptions: channelName , Speaker 2
10:56:34 T:6172241920   DEBUG: CPlexServices::Process has gateway1
10:56:34 T:6171095040   DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
10:56:34 T:6171095040   DEBUG:   Output Device : Default
10:56:34 T:6171095040   DEBUG:   Sample Rate   : 44100
10:56:34 T:6171095040   DEBUG:   Sample Format : AE_FMT_FLOAT
10:56:34 T:6171095040   DEBUG:   Channel Count : 2
10:56:34 T:6171095040   DEBUG:   Channel Layout: FL,FR
10:56:34 T:6171095040   DEBUG:   Frames        : 1024
10:56:34 T:6171095040   DEBUG:   Frame Size    : 8
10:56:34 T:6171095040   DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
10:56:34 T:6169374720  NOTICE: Running database version Addons20
10:56:34 T:6169374720   DEBUG: SECTION:LoadDLL(libcpluff.framework/libcpluff)
10:56:34 T:6169374720   DEBUG: Loading: /var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/Frameworks/libcpluff.framework/libcpluff
10:56:34 T:6169374720    INFO: ADDON: cpluff: 'Could not read plug-in directory /var/mobile/Containers/Data/Application/0090BCA9-1676-4B85-A18F-84CC95F89F58/Documents/MrMC/addons: No such file or directory'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ca_es has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mt_mt has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.az_az has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.vi_vn has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ja_jp has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.eo has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.images.weathericons.default has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pl_pl has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_au has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_ca has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.ofdb.de has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_af has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.bg_bg has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hu_hu has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.da_dk has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mk_mk has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_pt has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.nb_no has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.is_is has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ms_my has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sv_se has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ru_ru has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.os_os has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_mx has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.nl_nl has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ta_in has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in skin.re-touched has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.gl_es has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.slideshow has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in skin.opacity has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ko_kr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_ir has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.uz_uz has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.movieposterdb.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.tg_tj has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.my_mm has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.port.hu has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in visualization.spectrum has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hr_hr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_tw has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fo_fo has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_cn has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ro_ro has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fi_fi has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.de_de has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_nz has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.szl has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_us has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.tr_tr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.mrmc has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.mymovies.dk has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_br has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.id_id has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.th_th has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sk_sk has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sl_si has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.system has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.am_et has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_fr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_ar has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.eu_es has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.bs_ba has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs@latin has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.universal has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.cs_cz has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in skin.mrmc has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mi has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sq_al has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.el_gr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hi_in has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ml_in has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.hdhomerun has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.cy_gb has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.af_za has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.uk_ua has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.tvos has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hy_am has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.lt_lt has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.si_lk has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.it_it has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mn_mn has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ar_sa has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvshows.themoviedb.org has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.lv_lv has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.te_in has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.amber has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.et_ee has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.omdbapi.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.he_il has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_es has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Plug-in resource.language.be_by has been installed.'
10:56:34 T:6169374720   DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
10:56:34 T:6169374720    INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
10:56:34 T:6169374720   DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
10:56:34 T:6169374720   DEBUG: Current resolution Screen: 0 with 2048 x 1536
10:56:34 T:6169374720  NOTICE: Found possible resolution for display 0 with 1536 x 2048
10:56:34 T:6169374720  NOTICE: Checking resolution 16
10:56:34 T:6169374720   DEBUG: About to switch to 2048 x 1536 on screen 0
10:56:34 T:6169374720   DEBUG: Found matching mode
10:56:34 T:6169374720    INFO: GLES: Maximum texture width: 2048
10:56:34 T:6169374720   DEBUG: EGL_EXTENSIONS: GL_OES_standard_derivatives GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
10:56:34 T:6169374720  NOTICE: GL_VENDOR = Apple Inc.
10:56:34 T:6169374720  NOTICE: GL_RENDERER = Apple A7 GPU
10:56:34 T:6169374720  NOTICE: GL_VERSION = OpenGL ES 3.0 Apple A7 GPU - 111.47
10:56:34 T:6169374720  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
10:56:34 T:6169374720   DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
10:56:34 T:6169374720  NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
10:56:34 T:6169374720   DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 NO
10:56:34 T:6169374720   DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
10:56:34 T:6169374720   DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 YES
10:56:34 T:6169374720   DEBUG: GLES: Extension Support Test - GL_EXT_unpack_subimage NO
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x1539d8370
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x155381c10
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x155383050
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x155382120
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x1552defb0
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x1553807f0
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x155218b50
10:56:34 T:6169374720   DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x155382760
10:56:34 T:6169374720   DEBUG: GUI Shader [guishader_frag_rgba_bob.glsl]- Initialise successful : 0x1552de120
10:56:34 T:6169374720    INFO: GLES: Maximum texture width: 8192
10:56:34 T:6169374720    INFO: load keymapping
10:56:34 T:6169374720    INFO: Loading special://xbmc/system/keymaps/keyboard.xml
10:56:35 T:6169374720    INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
10:56:35 T:6169374720    INFO: GUI format 2048x1536, Display 2048x1536
10:56:35 T:6169374720   DEBUG: guilib: Fill viewport on change for solving rendering passes
10:56:35 T:6169374720    INFO: CLangInfo: loading resource.language.en_gb language information...
10:56:35 T:6169374720   DEBUG: trying to set locale to en_US.UTF-8
10:56:35 T:6169374720    INFO: global locale set to C
10:56:35 T:6169374720    INFO: CLangInfo: loading resource.language.en_gb language strings...
10:56:35 T:6169374720   DEBUG: POParser: loaded 3787 strings from file resource://resource.language.en_gb/strings.po
10:56:35 T:6169374720   DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
10:56:35 T:6169374720   DEBUG: LoadMappings - loaded node "CEC Adapter"
10:56:35 T:6169374720   DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
10:56:35 T:6169374720   DEBUG: LoadMappings - loaded node "iMON HID device"
10:56:35 T:6173388800  NOTICE: Running database version Addons20
10:56:35 T:6173388800   DEBUG: Initialize, updating databases...
10:56:35 T:6173388800  NOTICE: Running database version ViewModes6
10:56:35 T:6173388800  NOTICE: Running database version Textures13
10:56:35 T:6173388800  NOTICE: Running database version MyMusic60
10:56:35 T:6173388800  NOTICE: Running database version MyVideos107
10:56:35 T:6173388800  NOTICE: Running database version TV29
10:56:35 T:6173388800  NOTICE: Running database version Epg11
10:56:35 T:6173388800   DEBUG: Initialize, updating databases... DONE
10:56:35 T:6169374720    INFO: DPMS: not supported on this platform
10:56:35 T:6169374720   DEBUG: Activating window ID: 12997
10:56:35 T:6169374720   DEBUG: ------ Window Init () ------
10:56:35 T:6169374720    INFO: load splash image: /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/media/Splash.png
10:56:35 T:6169374720    INFO: Unloading old skin ...
10:56:35 T:6169374720    INFO:   load skin from: /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/addons/skin.re-touched (version: 5.1.1)
10:56:35 T:6169374720    INFO:   load fonts for skin...
10:56:35 T:6169374720    INFO: Loading fonts from /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/addons/skin.re-touched/16x9/Font.xml
10:56:35 T:6169374720   DEBUG: POParser: loaded 85 strings from file /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/addons/skin.re-touched/language/English/strings.po
10:56:35 T:6169374720    INFO: Loading skin includes from /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/addons/skin.re-touched/16x9/Includes.xml
10:56:35 T:6169374720    INFO:   load new skin...
10:56:35 T:6169374720    INFO: Loading user windows, path /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/addons/skin.re-touched/16x9
10:56:35 T:6169374720   DEBUG: Load Skin XML: 24.80ms
10:56:35 T:6169374720    INFO:   initialize new skin...
10:56:35 T:6169374720    INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720   DEBUG: OpenBundle - Opened bundle /private/var/containers/Bundle/Application/4E8824D8-83E5-46DB-90CD-C1E85767465E/MrMC.app/AppData/AppHome/addons/skin.re-touched/media/Textures.xbt
10:56:35 T:6169374720    INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720    INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720    INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720    INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720    INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720    INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
10:56:35 T:6169374720    INFO: Loading resource://resource.uisounds.mrmc/sounds.xml
10:56:35 T:6169374720    INFO:   skin loaded...
10:56:35 T:6169374720   DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
10:56:35 T:6169374720 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:56:35 T:6169374720    INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
10:56:35 T:6169374720    INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
10:56:35 T:6169374720    INFO: JSONRPC v6.32.5: Successfully initialized
10:56:35 T:6169374720   DEBUG: ADDON: Starting service addons.
10:56:35 T:6169374720   DEBUG: Activating window ID: 12999
10:56:35 T:6169374720   DEBUG: ------ Window Init (Startup.xml) ------
10:56:35 T:6169374720    INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
10:56:35 T:6169374720  NOTICE: ActiveAE DSP - starting
10:56:35 T:6169374720    INFO: removing tempfiles
10:56:35 T:6169374720  NOTICE: initialize done
10:56:35 T:6169374720  NOTICE: Running the application...
10:56:35 T:6169374720   DEBUG: Activating window ID: 10000
10:56:35 T:6169374720    INFO: GLES: Enabling VSYNC
10:56:35 T:6169374720    INFO: GLES: Selected vsync mode 10
10:56:35 T:6169374720   DEBUG: ------ Window Deinit (Startup.xml) ------
10:56:35 T:6169374720   DEBUG: ------ Window Init (Home.xml) ------
10:56:35 T:6169374720    INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
10:56:35 T:6169374720   ERROR: Window Translator: Can't find window filestackingdialog
10:56:35 T:6169374720   ERROR: Window Translator: Can't find window peripherals
10:56:35 T:6173388800   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
10:56:35 T:6169374720   ERROR: Control 9000 in window 10000 has been asked to focus, but it can't
10:56:35 T:6169374720   DEBUG: NetworkMessage - Starting network services
10:56:35 T:6169374720  NOTICE: starting zeroconf publishing
10:56:35 T:6169374720  NOTICE: WebServer: Started the webserver
10:56:35 T:6169374720  NOTICE: starting upnp client
10:56:35 T:6173962240   DEBUG: CZeroconfOSX::doPublishService identifier: servers.webserver type: _http._tcp name:MrMC (BRIANs-iPad-mini) port:8080
10:56:35 T:6173388800   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
10:56:35 T:6173388800   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:56:35 T:6173962240   DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:MrMC (BRIANs-iPad-mini) port:8080
10:56:35 T:6169374720    INFO: JSONRPC Server: Successfully initialized
10:56:35 T:6179123200  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
10:56:35 T:6179123200  NOTICE: UDP: Listening on port 9777
10:56:35 T:6173962240   DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:MrMC (BRIANs-iPad-mini) port:9090
10:56:35 T:6173388800   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:56:35 T:6173388800   DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:MrMC (BRIANs-iPad-mini) port:9777
10:56:35 T:6173962240   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:56:36 T:6173962240   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:56:36 T:6172241920   DEBUG: CPlexClient::Init serverName(GuzaPlex - Office), ipAddress(brianguza.mynetgear.com), protocol(http)
10:56:36 T:6172241920   DEBUG: CPlexClient::ParseSections GuzaPlex - Office found 3 movie sections
10:56:36 T:6172241920   DEBUG: CPlexClient::ParseSections GuzaPlex - Office found 3 shows sections
10:56:36 T:6172241920   DEBUG: CPlexClient::ParseSections GuzaPlex - Office found 0 artist sections
10:56:36 T:6172241920   DEBUG: CPlexClient::ParseSections GuzaPlex - Office found 1 photo sections
10:56:36 T:6172241920  NOTICE: CPlexServices: Server found via plex.tv GuzaPlex - Office
10:56:36 T:6173388800   DEBUG: CGUIWindowHome::Announce, type: 16, from xbmc, message UpdateRecentlyAdded
10:56:36 T:6173388800   DEBUG: CGUIWindowHome::Announce, type: 32, from xbmc, message UpdateRecentlyAdded
10:56:36 T:6180270080   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
10:56:37 T:6180270080   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
10:56:37 T:6180270080   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:56:41 T:6180270080   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:56:53 T:6169374720   DEBUG: Unfocus WindowID: 10000, ControlID: 9000
10:56:53 T:6169374720   DEBUG: Activating window ID: 10025
10:56:53 T:6169374720   DEBUG: ------ Window Deinit (Home.xml) ------
10:56:53 T:6169374720   DEBUG: ------ Window Init (MyVideoNav.xml) ------
10:56:53 T:6169374720    INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
10:56:53 T:6169374720   ERROR: Window Translator: Can't find window filestackingdialog
10:56:53 T:6169374720   ERROR: Window Translator: Can't find window peripherals
10:56:54 T:6169374720   ERROR: CGUITextureManager::GetTexturePath: could not find texture 'button-focus.png'
10:56:54 T:6169374720   ERROR: Previous line repeats 2 times.
10:56:54 T:6169374720   DEBUG: CServicesDirectory::GetDirectory
10:56:54 T:6169374720   DEBUG: CServicesDirectory::GetDirectory strURL = services://tvshows/titles/
10:56:54 T:6173962240   DEBUG: CPlexDirectory::GetDirectory
10:56:54 T:6173962240   DEBUG: CPlexDirectory::GetDirectory strURL = plex://tvshows/titles/
10:56:54 T:6173962240   DEBUG: CPlexDirectory::GetDirectory client(GuzaPlex - Office), title(Plex(O) - GuzaPlex - Office - PlayOn - TV )
10:56:54 T:6173962240   DEBUG: CPlexDirectory::GetDirectory client(GuzaPlex - Office), title(Plex(O) - GuzaPlex - Office - TV - DVR )
10:56:54 T:6173962240   DEBUG: CPlexDirectory::GetDirectory client(GuzaPlex - Office), title(Plex(O) - GuzaPlex - Office - ZZZ Test )
10:56:56 T:6169374720   DEBUG: Unfocus WindowID: 10025, ControlID: 50
10:56:56 T:6180843520   DEBUG: CPlexDirectory::GetDirectory
10:56:56 T:6180843520   DEBUG: CPlexDirectory::GetDirectory strURL = plex://tvshows/titles/aHR0cDovL2JyaWFuZ3V6YS5teW5ldGdlYXIuY29tOjMyNDAwL2xpYnJhcnkvc2VjdGlvbnMvMjAvYWxsfCZYLVBsZXgtVG9rZW49RlVMQjFtV21LUzZGaTNkTnZGZlI=
10:56:57 T:6180843520   ERROR: CPlexUtils::ParsePlexSeries invalid response from http://HOSTNAME:32400/library/sections/20/all|&X-Plex-Token=PLEXTOKEN
10:56:57 T:6180843520   DEBUG: CPlexDirectory::GetDirectory' client(GuzaPlex - Office), found 0 shows
10:58:18 T:6169374720   DEBUG: Unfocus WindowID: 10025, ControlID: 0
10:58:18 T:6169374720   DEBUG: Activating window ID: 10000
10:58:19 T:6169374720   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
10:58:19 T:6169374720   DEBUG: ------ Window Init (Home.xml) ------
10:58:19 T:6180843520   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
10:58:19 T:6180843520   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
10:58:20 T:6169374720   DEBUG: Unfocus WindowID: 10000, ControlID: 9002
10:58:20 T:6169374720   DEBUG: Activating window ID: 10004
10:58:20 T:6169374720   DEBUG: ------ Window Deinit (Home.xml) ------
10:58:20 T:6169374720   DEBUG: ------ Window Init (Settings.xml) ------
10:58:20 T:6169374720    INFO: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
10:58:20 T:6169374720   ERROR: Window Translator: Can't find window filestackingdialog
10:58:20 T:6169374720   ERROR: Window Translator: Can't find window peripherals
10:58:20 T:6173962240   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:58:23 T:6169374720   DEBUG: Unfocus WindowID: 10004, ControlID: 9002
10:58:23 T:6169374720   DEBUG: Activating window ID: 10007
10:58:23 T:6169374720   DEBUG: ------ Window Deinit (Settings.xml) ------
10:58:23 T:6169374720   DEBUG: ------ Window Init (SettingsSystemInfo.xml) ------
10:58:23 T:6169374720    INFO: Loading skin file: SettingsSystemInfo.xml, load type: KEEP_IN_MEMORY
10:58:23 T:6173962240   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:58:27 T:6169374720   DEBUG: Unfocus WindowID: 10007, ControlID: 9002
10:58:27 T:6169374720   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
10:58:27 T:6169374720   DEBUG: ------ Window Deinit (SettingsSystemInfo.xml) ------
10:58:27 T:6169374720   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
10:58:27 T:6169374720   DEBUG: ------ Window Init (Settings.xml) ------
10:58:34 T:6169374720   DEBUG: Unfocus WindowID: 10004, ControlID: 9000
10:58:34 T:6169374720   DEBUG: Activating window ID: 10018
10:58:34 T:6169374720   DEBUG: ------ Window Deinit (Settings.xml) ------
10:58:34 T:6169374720   DEBUG: ------ Window Init (SettingsCategory.xml) ------
10:58:34 T:6169374720    INFO: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
10:58:34 T:6169374720   ERROR: Window Translator: Can't find window filestackingdialog
10:58:34 T:6169374720   ERROR: Window Translator: Can't find window peripherals
10:58:37 T:6169374720   DEBUG: Unfocus WindowID: 10018, ControlID: -93
brian@guzanet.com
Post by brian@guzanet.com » 16 Mar 2018, 12:34
Any possibility to review this?
Brian
brian@guzanet.com
Post by brian@guzanet.com » 20 Mar 2018, 22:01
Hi. Can this be looked at please?
Post by timstephens24 » 20 Mar 2018, 22:17
Does it show in the Plex app?
brian@guzanet.com
Post by brian@guzanet.com » 20 Mar 2018, 22:46
Yes, there are no problems in Plex. The single season and all four episodes are visible from PMS.
Post by amet » 21 Mar 2018, 06:23
brian@guzanet.com wrote:
20 Mar 2018, 22:46
any chance you can add me as a "friend" on that plex library? would like to try in my debugging environment
user: ametovic
brian@guzanet.com
Post by brian@guzanet.com » 21 Mar 2018, 09:20
I have invited you. Thanks.
Post by amet » 21 Mar 2018, 09:25
Will look into it later, thanks!
