Forces ATV to stay awake/screensaver
RewNex
Post by RewNex » 04 Mar 2018, 06:38
Hi all new here.
When playback is ending the screensaver should kick in (which it does) but then after depending on atv settings it should go to sleep which it does not, so when falling to sleep watching a movie waking up in the morning everything is still on tv, receiver and atv, MrMC is the only app that does this that I know of and will highly hope it can be fixed,
thanks for an otherwise awesome playback experience.
Re: Forces ATV to stay awake/screensaver
Post by amet » 04 Mar 2018, 12:03
Will investigate...
Post by davilla » 04 Mar 2018, 15:19
RewNex wrote:
04 Mar 2018, 06:38
Hi all new here.
I assume you mean the tvOS screensaver, yes ? When the tvOS screensaver is running, we are pushed into the background and no longer have any influence.
RewNex
Post by RewNex » 04 Mar 2018, 16:35
Yes your right its the tvOS screensaver, somehow it goes on for hours if MrMC was the used app before kicking in, I have thought of if it could be "keep audio device alive" which I had set to always and are now testing it with 5min instead.
Post by cosmoxl » 04 Mar 2018, 16:45
It's my experience as well that if MrMC is still running the ATV won't go to sleep. Even though the tvOS screensaver activates.
Post by davilla » 04 Mar 2018, 18:48
Just tested with current 3.5.1 TestFlight.
ScreenSaver set to kick in in 5 min.
System Sleep set to 15 min.
Worked as expected. ScreenSaver kicked in 1st, then it went to sleep.
RewNex
Post by RewNex » 05 Mar 2018, 19:36
Sounds good, will report back I'm still not done testing if it could have been the setting "Keep audio device alive"
anyway thanks for the support ;)
RewNex
Post by RewNex » 07 Mar 2018, 05:35
So the "keep audio device alive" setting had nothing to do with forcing Appletv4k to stay awake, I'm still on 3.5 so can't wait till trying 3.5.1 that you say dosen't have this issue.
Post by cosmoxl » 07 Mar 2018, 05:43
Are you using the aerial screensaver, or another one?
RewNex
Post by RewNex » 07 Mar 2018, 18:25
cosmoxl wrote:
07 Mar 2018, 05:43
Yes Aerial, start after 2min sleep after 30min.
Users browsing this forum: Spindel and 2 guests
