Cannot toggle 3d in Pause-OSD-Menu with Amber Skin
Londo2017
Post by Londo2017 » 15 Feb 2018, 21:55
Thanks for changing the Emby Collections issue...one last issue and than i will be happy forever :-)
When using Amber Skin with a 3D Movie you cannot switch 3d off in the Pause Menu. Because the 3d Button is „grey“ / without use, the context of the 3d menu is also displayed when you are on the subtitle button (as overlay)
So you have no menu opening on 3d button and 2 menus opening on subtitle button.
When i want to watch a 3d movie in 2d, i have to switch skin :-( But Amber is my first choice and the best skin for me...can you fix this?
Re: Cannot toggle 3d in Pause-OSD-Menu with Amber Skin
Post by amet » 16 Feb 2018, 05:46
Can you take a quick photo of the workin skin button and non working one on amber?
Post by amet » 16 Feb 2018, 18:07
ok, fixed... its coming to 3.5.1
Londo2017
Post by Londo2017 » 16 Feb 2018, 21:35
:-) Just took the pics 3 minutes ago - But thats even better :-)
Wow superfast! Thats what I call support - Thanks a alot!
Londo2017
Post by Londo2017 » 30 Mar 2018, 20:21
Hey @amet
You mentioned, that you will fix this problem with 3.5.1 - But with 3.6 its still there :-(
Post by amet » 31 Mar 2018, 04:10
hm, I thought I did ... I have had the working 3D submenu for sure..
what are you seeing? lets see a photo please
Londo2017
Post by Londo2017 » 31 Mar 2018, 14:13
In Amber:
„Empty“ 3d button with no use
https://ibb.co/eCrpVS
„Double layered“ subtitle button with the unusable 3d mode visible
https://ibb.co/eqK9VS
Post by amet » 31 Mar 2018, 14:18
Hm, you are using Siri in expert mode... I was checking with a latest Siri changes
Londo2017
Post by Londo2017 » 31 Mar 2018, 14:25
And this means? Can it not be fixed without changing the OSD to the other mode?
Post by amet » 31 Mar 2018, 14:45
Yes it can, I just looked at the new osd mode as that’s when you reported it.
I’ll have a look and let you know
