HDR mrmc all gray blacks are all over bright
haffi@haffi.is
Post by haffi@haffi.is » 11 Feb 2018, 17:52
Appletv4k
Philips 4k 8k series.
With HDR all os over birght :(
If I turn off HDR all looks good, this is just the MRMC app , plex and netflix are fine ?
Is this a bug?
Re: HDR mrmc all gray blacks are all over bright
Post by davilla » 11 Feb 2018, 18:06
fixed in testflight
haffi@haffi.is
Post by haffi@haffi.is » 11 Feb 2018, 19:26
Great ! God Job !
haffi@haffi.is
Post by haffi@haffi.is » 18 Feb 2018, 21:16
Did this fix not make it to 3.5 ?
Post by cosmoxl » 18 Feb 2018, 21:30
haffi@haffi.is wrote:
18 Feb 2018, 21:16
Yes, 3.5 has fixes for HDR material.
Make sure you're using AVFoundation as decoder for HDR material.
haffi@haffi.is
Post by haffi@haffi.is » 18 Feb 2018, 21:41
The ui is still all greyish if I turn on HDR 4k, and also the video playback video setting are using defaults.
Post by davilla » 18 Feb 2018, 22:16
Video -> Playback -> Adjust display refresh rate = Always
Video -> Acceleration -> Allow hardware acceleration - VideoToolbox = Checked
Video -> Acceleration -> - Use VideoToolBox for 4K HEVC HDR content = Unchecked
Video -> Acceleration -> Allow hardware acceleration - AVFoundation = Checked
Otherwise, debuglog and we need to see a screenshot to see what you are talking about.
haffi@haffi.is
Post by haffi@haffi.is » 19 Feb 2018, 00:43
Will do more tests , tomorrow thanks.
haffi@haffi.is
Post by haffi@haffi.is » 19 Feb 2018, 20:36
Nope its still the same even with these settings.
Here is when Signal is in 4k SDR 60hz
Here is when signal is in 4k HDR 60hz
Pictures don't really show how much it is but there is alot of difference, I have to take the HDR signal and cut the birghtness to 38% for desent black but then also other stuff looks bad.
Note this also is when playing the same "non" black or grayblack is present. So you don't get the deep black color.
Netflix is the same ( i.e. Black is fine in both modes and other apps so its mrmc in both Modes of AppleTV.
Log is here
http://haffi.is/mrmc-no-true-blacks.txt
Post by cosmoxl » 19 Feb 2018, 22:05
I don't think the shade of the GUI is the important thing here. I thought you were talking about how video playback looks.
