Problems with WOA / Network
TheDoctor
Post by TheDoctor » 02 Feb 2018, 09:17
Hi.
On my initial installation of MrMc I set up Wake on Access. After activating, it showed me the message "Setting MAC-Adress successful". WOA seems not to be working. Looks like the MAC didn't get saved:
09:53:34 T:6098661376 NOTICE: WakeOnAccess - Load settings :
09:53:34 T:6098661376 NOTICE: WakeOnAccess - Enabled:TRUE
09:53:34 T:6098661376 NOTICE: -Network init timeout : [20] sec
09:53:34 T:6098661376 NOTICE: -Network settle time : [500] ms
09:53:34 T:6098661376 NOTICE: Registering wakeup entry:
09:53:34 T:6098661376 NOTICE: HostName : 192.168.1.100
09:53:34 T:6098661376 NOTICE: MacAddress : 02:00:00:00:00:00
09:53:34 T:6098661376 NOTICE: PingPort : 0
09:53:34 T:6098661376 NOTICE: PingMode : 0
09:53:34 T:6098661376 NOTICE: Timeout : 300 (sec)
09:53:34 T:6098661376 NOTICE: WaitForOnline : 40 (sec)
09:53:34 T:6098661376 NOTICE: WaitForOnlineEx : 40 (sec)
09:53:34 T:6098661376 NOTICE: WaitForServices : 5 (sec)
09:53:34 T:6100381696 NOTICE: bool CAAudioUnitSink::setupAudio
I tried several times to reset the WOA in the GUI, same result (IP is correct).
The same Server wakes up just fine by WOL using different Kodi-Installations or by using etherwake.
Another thing I noticed while testing:
MrMc seems not to be waiting for network to be ready at launch.
After restarting the ATV 4k MrMc is not able to start the webserver, the GUI shows "Starting Webserver failed".
Also Network-Shares (server was up in this scenario) are not available. After some seconds, shares are available but the webserver has to be started again via GUI in order to be running.
Full Debug-Log
