Exclude Folder?
Depechefan
Exclude Folder?
Post by Depechefan » 01 Feb 2018, 19:19
Is there a way to exclude a folder from a library?
/M
Re: Exclude Folder?
Post by amet » 01 Feb 2018, 19:29
no, there is no way to exclude the subfolder
EDIT: I stand corrected
adding below to advancedsettings.xml might work
<video>
  <excludefromscan>
    <regexp>-trailer</regexp>
    <regexp>[!-._ \\/]sample[-._ \\/]</regexp>
  </excludefromscan>
</video>
just edit <regexp></regexp> to exclude folder you dont want
Re: Exclude Folder?
Post by davilla » 01 Feb 2018, 19:35
what are you trying to exclude ?
Depechefan
Re: Exclude Folder?
Post by Depechefan » 01 Feb 2018, 20:09
I'm using a program which synchronizes folders between to disks. It puts a folder named _gsdata_ at the top level of the folder it synchronizes (on both disks).
Depechefan
Re: Exclude Folder?
Post by Depechefan » 01 Feb 2018, 20:12
Where should I place advancedsettings.xml?
