TvOs 11.3 beta no audio only noise
Golge77
Post by Golge77 » 26 Jan 2018, 16:14
After installing 11.3 beta I lost all sound in MrMc I'm only get noise in the speakers.
It doesn't matter if it's 2 channel or 5.1 etc.
Sound works in Infuse 5 pro and other streaming apps
anyone else having this problem?
Re: TvOs 11.3 beta no audio only noise
Post by cosmoxl » 26 Jan 2018, 16:18
how is your sound setup in MrMC and in the tvOS settings?
I have the 11.3 beta on an ATV4k and an ATV4 with no problems that I've noticed.
Golge77
Post by Golge77 » 26 Jan 2018, 16:33
MrMc
* 7.1
* Optimized
* Keep original volume......
* Resampling quality ............High
* passthrough:
* Dolby digital AC3
* DTS
tvOs
* Sound output: AppleTV4k
* Surroundsound: Best available quality
I have my menus in other language so I'm not sure if my translation is the right one ....
After some more testing it seems like the problem is with dolby digital sounds 2.0, 5.1 and 7.1
AAC 2.0, 5.1 and 7.1 works
Post by cosmoxl » 26 Jan 2018, 16:45
Golge77 wrote:
26 Jan 2018, 16:33
MrMc
* 7.1
* Optimized
* passthrough:
* Dolby digital AC3
* DTS
tvOs
Right, so it's passthrough that's not working since AAC works. This is typical of betas. If your audio sink can take multi channel PCM, turning off passthrough in MrMC is probably the best choice for stability and quality.
Golge77
Post by Golge77 » 26 Jan 2018, 16:49
Why does it work in Infuse and not in MrMc?
If passthrough was broken I should have the same problem with Infuse.
Post by davilla » 26 Jan 2018, 16:52
Golge77 wrote:
26 Jan 2018, 16:49
If Infuse was open source and I could look at their audio code handling, then I could answer that question. :)
Seriously, this is the 1st beta of tvOS 11.3, surly you guys would learn by now, never test the 1st beta of a version bump. There is always something that breaks. I never, ever install the 1st beta of anything. It's just a waste of time.
Post by cosmoxl » 26 Jan 2018, 16:53
Golge77 wrote:
26 Jan 2018, 16:49
I couldn't tell you. So in Infuse you have it set to passthrough, not auto?
Golge77
Post by Golge77 » 26 Jan 2018, 17:02
26 Jan 2018, 16:52
Golge77 wrote:
26 Jan 2018, 16:49
There's no rush a new beta coming soon anyway.... meanwhile I can use infuse and I also have 2 Nvidia Shields so I can watch my movies/series anyway
Post by cosmoxl » 26 Jan 2018, 19:44
Golge77 wrote:
26 Jan 2018, 17:02
26 Jan 2018, 16:52
Golge77 wrote:
26 Jan 2018, 16:49
I don't know what content your video files have but you really will get better audio decoding by disallowing passthrough. You see, if passthrough is enabled then MrMC in tvOS will try to passthrough the DTS core of DTS-HD. If passthrough is disabled then it will decode DTS-HD and output PCM. Just a thought. I know I'd rather have DTS-HD.
Golge77
Post by Golge77 » 27 Jan 2018, 04:11
probably I have to reverse my thinking when setting up AppleTV.
I'm used to other mediaplayers and for atleast 10 years I have set passthrough in settings to let amplifier decode and show Dolby Digital, DTS and lately DtsHD-MA, TrueHD and Atmos.
I will try to skip passthrough and see what happens
Users browsing this forum: ionutm80 and 6 guests
