loads customcontroller.SiriRemote.xml from system, not from "special://masterprofile/"11:55:03 T:6165770240 INFO: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
New to Apple TV 4K & MrMC. Help needed.
Re: New to Apple TV 4K & MrMC. Help needed.
But I only have access to copy the file to 1 keymap folder..
Any help?
Have someone it working with mappen bottoms?
I honestly have no idea what you are doing wrong, can you please post modified keymap file so we can check it for errors and let us know where you are copying from and to where. Capture that on debuglog please as there might be some info regarding copying in it.
Here is what I want in customcontroller.SiriRemote.xml
Can you please test and see if it's working for you?
The changed items I have placed to the left in the .xml file.
<?xml version="1.0" encoding="UTF-8"?>
<!-- This file contains the mapping of keys (gamepad,remote and keyboard) to actions within XBMC -->
<!-- The <global> section is a fall through - they will only be used if the button is not -->
<!-- used in the current window's section. Note that there is only handling -->
<!-- for a single action per button at this stage. -->
<!-- For joystick/gamepad configuration under linux/win32, see below as it differs from xbox -->
<!-- gamepads. -->
<!-- The format is: -->
<!-- <device> -->
<!-- <button id=""#>xbmc action</button>
<!-- </device> -->
<!-- To map keys from other remotes using the RCA protocol, you may add <customcontroller name="SiriRemote"> blocks -->
<!-- In this case, the tags used are <button id=""#> where # is the original button code (OBC) of the key -->
<!-- You set it up by adding a <customcontroller name="SiriRemote"> block to the window or <global> section: -->
<!-- <customcontroller name="SiriRemote"> -->
<!-- <button id="45">Stop</button>
<!-- </customcontroller> -->
<!-- Note that the action can be a built-in function. -->
<!-- eg <button id="6">ActivateWindow(Favourites)</button>
<!-- would bring up Favourites when the button with the id of 6 is press. In this case, "Menu" -->
<!-- Button Ids: -->
<!-- 'id' is the button ID used by SDL. The key ids recognized from your remote appears -->
<!-- in /var/log/syslog on the ATV2 for each button pressed and when debug mode is enabled -->
<!-- Use your log to discover and map custom buttons to actions. -->
<keymap>
<global>
<!-- tap/ir up --> <button id="1">Up</button>
<!-- tap/ir down --> <button id="2">Down</button>
<!-- tap/ir left --> <button id="3">Left</button>
<!-- tap/ir right --> <button id="4">Right</button>
<!-- tap/ir center --> <button id="5">Select</button>
<!-- menu --> <button id="6">ContextMenu</button>
<!-- hold center --> <button id="7">noop</button>
<!-- swipe up --> <button id="8">Up</button>
<!-- swipe down --> <button id="9">Down</button>
<!-- swipe left --> <button id="10">Left</button>
<!-- swipe right --> <button id="11">Right</button>
<!-- play/pause --> <button id="12">PlayPause</button>
<!-- ir play --> <button id="13">Play</button>
<!-- ir pause --> <button id="14">Pause</button>
<!-- ir stop --> <button id="15">Stop</button>
<!-- ir next track --> <button id="16">info</button>
<!-- ir prev track --> <button id="17">SkipPrevious</button>
<!-- ir fast forward --> <button id="18">FastForward</button>
<!-- ir rewind --> <button id="19">Rewind</button>
<!-- menu at home --> <button id="20">PreviousMenu</button>
<!-- swipe left/up --> <button id="21">ScrollUp</button>
<!-- swipe right/down --><button id="22">ScrollDown</button>
<!-- page up --> <button id="23">PageUp</button>
<!-- page down --> <button id="24">PageDown</button>
</customcontroller>
</global>
<Home>
</customcontroller>
</Home>
<FullscreenVideo>
<button id="1">subtitledelayplus</button>
<button id="2">subtitledelayminus</button>
<button id="3">StepBack</button>
<button id="4">StepForward</button>
<button id="5">OSD</button>
<button id="6">info</button>
<button id="7">Pause</button>
<button id="8">noop</button>
<button id="9">noop</button>
<button id="10">StepBack</button>
<button id="11">StepForward</button>
<button id="16">activatewindow(subtitlesearch)</button>
<button id="17">nextsubtitle</button>
</customcontroller>
</FullscreenVideo>
<FullscreenLiveTV>
<button id="1">ActivateWindow(PVROSDChannels)</button>
<button id="2">ActivateWindow(PVROSDChannels)</button>
<button id="6">activatewindow(teletext)</button>
<button id="7">ActivateWindow(PVROSDChannels)</button>
<button id="10">noop</button>
<button id="11">noop</button>
<button id="16">channelup</button>
</customcontroller>
</FullscreenLiveTV>
<FullscreenRadio>
</customcontroller>
</FullscreenRadio>
<Visualisation>
<button id="1">noop</button>
<button id="2">noop</button>
<button id="3">SkipPrevious</button>
<button id="4">SkipNext</button>
<button id="5">Pause</button>
<button id="6">Fullscreen</button>
<button id="7">OSD</button>
</customcontroller>
</Visualisation>
<SlideShow>
<button id="1">ZoomIn</button>
<button id="2">ZoomOut</button>
<button id="3">PreviousPicture</button>
<button id="4">NextPicture</button>
<button id="6">Stop</button>
<button id="7">Info</button>
</customcontroller>
</SlideShow>
<ScreenCalibration>
<button id="5">NextCalibration</button>
</customcontroller>
</ScreenCalibration>
<VideoOSD>
<button id="7">Back</button>
</customcontroller>
</VideoOSD>
<VideoMenu>
</customcontroller>
</VideoMenu>
<PictureInfo>
</customcontroller>
</PictureInfo>
</keymap>
<!-- gamepads. -->
<!-- <device> -->
<!-- </device> -->
<keymap>
<global>
</customcontroller>
</global>
<Home>
</customcontroller>
</Home>
<FullscreenVideo>
</customcontroller>
</FullscreenVideo>
<FullscreenLiveTV>
</customcontroller>
</FullscreenLiveTV>
<FullscreenRadio>
</customcontroller>
</FullscreenRadio>
<Visualisation>
</customcontroller>
</Visualisation>
<SlideShow>
</customcontroller>
</SlideShow>
<ScreenCalibration>
</customcontroller>
<VideoOSD>
</customcontroller>
</VideoOSD>
<VideoMenu>
</customcontroller>
</VideoMenu>
<PictureInfo>
</customcontroller>
</PictureInfo>
</keymap>
looking into this.
The picture on mrmc doesn't show the XML file from my side.
Does the XML file i have created work on your side?
Picture is showing you that davilla fixed it, it will be in the next version
