Channel Icons not present - mythtv pvr
khelder
Post by khelder » 12 Jan 2018, 10:55
Long time Kodi/Libreelec user and I've just installed MrMC on my new ATV4K. So far I'm impressed.
I've run into an issue where the TV channel Icons won't appear when using the MythTV PVR plugin. I'm running 0.28 backend.
I've captured some Debug logging and came across this:
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1001 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1011 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1013 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1020 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1022 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1023 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1024 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1030 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1031 failed.
21:47:08 T:6159806464   DEBUG: LoadFromFileInternal - Load of /var/mobile/Containers/Data/Application/F28156AB-75DA-4F47-9F2D-A7600AEC351D/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1033 failed.
21:47:10 T:6159806464   DEBUG: Previous line repeats 1 times.
I've tried clearing the cache and reloading a few times but this doesn't appear to fix the issue.
Is there something I can do to address this? Happy to provide more logging if required.
Thanks.
Re: Channel Icons not present - mythtv pvr
Post by davilla » 12 Jan 2018, 12:10
we will look into it.
zakaron
Post by zakaron » 20 Jan 2018, 17:35
I actually notice the same thing as well. I'm running MythTV 0.27 on FreeBSD
When I look at the TV channel section, it shows some stations with a default movie camera icon and others as blank. Never gave it much thought and figured it may load faster like that anyway. Here is some detail from the debug I saw on mine with the channel icons:
 23:30:33 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)WSResponse: bad request (404)
23:30:33 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)GetChannelIcon1_32: invalid response
23:30:33 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: Process: Failed to read file: type: 4, local: /var/mobile/Containers/Data/Application/E93CA314-C869-44A5-8509-60542522BA34/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1104
23:30:43 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)WSResponse: bad request (404)
23:30:43 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)GetChannelIcon1_32: invalid response
23:30:43 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: Process: Failed to read file: type: 4, local: /var/mobile/Containers/Data/Application/E93CA314-C869-44A5-8509-60542522BA34/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1104
23:30:53 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)WSResponse: bad request (404)
23:30:53 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)GetChannelIcon1_32: invalid response
23:30:53 T:6186987520   ERROR: AddOnLog: MythTV PVR Client: Process: Failed to read file: type: 4, local: /var/mobile/Containers/Data/Application/E93CA314-C869-44A5-8509-60542522BA34/Library/Caches/home/userdata/addon_data/pvr.mythtv/cache/channelIcon/1104
