HVEC stuttering on v3.3 Apple TV 4
robvnet
Post by robvnet » 04 Dec 2017, 11:20
Hi, I'm finding HVEC files are stuttering during playback on the latest MrMC build v3.3 on my Apple TV 4. The videos play fine for the first 30 or so seconds, then they start stuttering badly.
This was an issue in 3.1 but was resolved in 3.2 with HVEC playing back beautifully.
Any ideas on how to resolve this?
Rob
Re: HVEC stuttering on v3.3 Apple TV 4
Post by amet » 04 Dec 2017, 15:02
hey, welcome to the forums...
lets us please see the debuglog while the issue is happening
Post by davilla » 04 Dec 2017, 16:14
defiantly need a debuglog on this, mediainfo on something that stutters would be good too.
robvnet
Post by robvnet » 06 Dec 2017, 11:19
Thanks for the replies.
Here's the log - https://pastebin.com/j0FusMmR
And MediaInfo:
General
Unique ID : 217071108238811449500083840361574852411 (0xA34E5FEF14E0A09190D15BE17A72673B)
Complete name : /Volumes/video/Suits S04/Suits.S04E16.1080p.10bit.BluRay.5.1.x265.HEVC-MZABI.mkv
Format : Matroska
File size : 480 MiB
Duration : 45mn 27s
Overall bit rate : 1 475 Kbps
Encoded date : UTC 2016-05-09 01:06:13
Writing application : mkvmerge v9.0.1 ('Obstacles') 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Video
Format : HEVC
Format profile : Main 10@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 45mn 27s
Bit rate : 1 281 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.390 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.025
Stream size : 417 MiB (87%)
Writing library : x265 1.9:[Linux][GCC 4.6.2][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=3 / tu-inter-depth=3 / me=3 / subme=4 / merange=57 / rect / amp / max-merge=4 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / no-open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=24 / scenecut=40 / rc-lookahead=40 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=1 / limit-modes / weightp / weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=6 / psy-rd=2.00 / rdoq-level=2 / psy-rdoq=1.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=2 / pass / bitrate=1281 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Format settings : Implicit
Codec ID : A_AAC-2
Duration : 45mn 27s
Bit rate : 192 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz / 24.0 KHz
Frame rate : 23.438 fps (1024 SPF)
Compression mode : Lossy
Stream size : 62.4 MiB (13%)
Title : MZABI
Language : English
Default : Yes
Forced : No
Finally, unrelated but another issue I've found in 3.3 is that the interface stretches bigger than my TV size so I've had to re-adjust the overscan settings on a couple of occasions.
Post by davilla » 06 Dec 2017, 13:01
MrMC 3.3-0 on an AppleTV4 (TVOS 11.1)
Well, 1st thing is a Frame rate of 24.390 fps is just wrong. That matches no known video frame rate I know.
I also doubt that the original source is 10bit. The people creating it just have no clue what the are doing.
DEBUG: OutputPicture - change configuration. 1920x1080. framerate: 24.39. format: BYPASS
DEBUG: UpdateFrameRateTracking: detected new fps(23.976024) at frame(4)
We see eventually see the right frame rate but AVFoundation will have it wrong internally.
More disturbing is the flood of:
21:16:37 T:7260467904   DEBUG: -[MainController displayLinkTick:]: displayRate = 59.949345
21:16:37 T:7260467904   DEBUG: -[MainController displayLinkTick:]: displayRate = 60.090134
21:16:37 T:7260467904   DEBUG: -[MainController displayLinkTick:]: displayRate = 59.790585
21:16:37 T:7260467904   DEBUG: -[MainController displayLinkTick:]: displayRate = 60.086525
This value comes from DisplayLink duration which should be rock solid stable. For '60Hz' it should be something like 59.94005994005994 or 1001/60000.
With the display rate wandering around, I would not doubt there would be stuttering.
Are you in the USA or elsewhere. What is the TV standard frame rate ? 60 or 50 ?
Post by davilla » 06 Dec 2017, 13:18
Let's get you into Testflight for v3.3.1 and see if that makes any difference.
viewtopic.php?f=10&t=1468
Post by davilla » 06 Dec 2017, 14:32
ok, displayRate spew is AppleTv4 related. Normal behavior for it. An upcoming testflight v3.3.1 will have it silenced.
I've rechecked some reference HEVC content I use. Rock solid and very smooth playback on the AppleTV4 (tvOS 11.2GM)
robvnet
Post by robvnet » 06 Dec 2017, 21:13
Thanks for the detailed response :)
I'm in Australia.
Regarding issues with the way the video files are created, I can confirm they worked perfectly in 3.2.
So 3.2 was able to handle this where as 3.3 is struggling to do so :?
I've installed 3.3-1 via Testflight. Unfortunately is has the exact same stutter issues.
Post by davilla » 07 Dec 2017, 16:34
in settings -> video -> videotoolbox -> enabled HEVC HDR content. Turn this on to vector to VideoToolBox codec.
robvnet
Post by robvnet » 09 Dec 2017, 00:03
07 Dec 2017, 16:34
Ok, I've just tried the latest build without enabling this setting and the affected HEVC videos are playing back beautifully again.
Issue resolved for now :)
Thanks again for your responsive support!
Users browsing this forum: Selest, Tonyj64 and 3 guests
