im missing the "Add Timer" (or similar name) option within EPG view. As backend Im using NextPVR, which runs very fine, other KODI installations (17.5) showing this option within EPG and I can use it when I click on an TV show. But within MrMC it only shows "Switch", "Find similar", and "Record" ( i don't know the english names at the moment, but you know what I mean ).
Any suggestions here?
No timer within EPG view [SOLVED]
Re: No timer within EPG view [SOLVED]
Hey,
I just solved this by myself. You need a long press on the tv show to get the context menu, and here is the timer setting.
Thx.
Thx.
