[SOLVED] single 'OK' button press to select a live tv channel in EPG
lippythelog
Post by lippythelog » 08 Sep 2017, 19:34
Hi All
Is there an option to be selected which allows a single 'ok' press to select a programme when in the live TV EPG and it is then shown without the pop up box with 'switch' on it been displayed?
This in principal is the same as it would be in 'sky' EPG when you select the channel and press 'ok' the programme then is displayed straight away.
Thanks in advance.
Lippy
zakaron
Re: single 'OK' button press to select a live tv channel in EPG
Post by zakaron » 09 Sep 2017, 04:59
Yes, this is how I have my guide selection set. Just go to Settings --> TV --> Guide. You'll see an option in there called "Default Select Action". Change this to "Switch to Channel". Hope this helps!
lippythelog
Post by lippythelog » 09 Sep 2017, 13:04
You kind sir are an absolute star :) :)
My kudos with the wife has now appreciably improved.
Many thanks
Lippy
