MrMC and ATV airplay receiver
steve1977
Post by steve1977 » 02 Aug 2017, 07:55
I love using MrMC on my ATV to watch movies. Also, I like to stream videos and audio to ATV.
Unfortunately, I need to close MrMC before I can stream video and audio to my ATV via airplay. Streaming video (when MrMC is open) results in one video being shown, but doesn't play and no audio. Streaming audio does not work at all and I am getting an error message.
Would be great if there is a way that I could stream to my ATV with airplay without the need to close MrMC. Any chance?
zakaron
Re: MrMC and ATV airplay receiver
Post by zakaron » 02 Aug 2017, 11:38
That is odd because my wife airplays Spotify all the time with no issue. MrMC will be sitting at a menu and she can start the airplay just fine. As far as I know, I have all software up to date on my ATV4. Will it give the same error for any airplay app you try? I do not have any special audio settings in MrMC set either (like passthrough).
Post by davilla » 02 Aug 2017, 12:53
No problem streaming to atv4 via airplay with MrMC running. Do it all the time to watch PBS Newshour.
steve1977
Post by steve1977 » 02 Aug 2017, 16:27
Good old trick. Restarted itunes, now all working. No idea why it worked when MrMC was closed though. Anyhow, all solved and working now. Thanks for your quick replies.
steve1977
Post by steve1977 » 12 Aug 2017, 04:44
Mmh... Having another issue with ATV airplay receiver (and this time restarted not to avoid same embarassment).
I am playing airplay to my ATV (MrMC closed). Now, I am opening MrMC and typically the airplay stream stops. I have disabled the GUI audio clicks as I thought this may be interferring. It is easy to replicate, but not consistent. Sometimes it works a bit, but then eventually always stops.
Any idea?
steve1977
Post by steve1977 » 22 Aug 2017, 03:57
Quick follow-up. Let me know if you need my help in trouble-shooting this issue? Thanks!
steve1977
Post by steve1977 » 30 Aug 2017, 04:13
Feels bad to push again, but this is really bogging me and preventing me from effectively using airplay in combination with MrMC. Any thought whether this could be addressed?
Post by cosmoxl » 30 Aug 2017, 04:22
steve1977 wrote:
12 Aug 2017, 04:44
Any idea?
The problem is that the airplay stream stops when you open MrMC?
steve1977
Post by steve1977 » 30 Aug 2017, 09:43
Thanks. Yes. And/or when browsing through menus once the airplay stream is active. Airplay is streamed to the ATV (not to MrMC native airplay receiver).
Post by cosmoxl » 30 Aug 2017, 15:56
steve1977 wrote:
30 Aug 2017, 09:43
Since MrMC is used to play video itself I think this behavior is "working as intended". Once you call up another app which plays audio/video tvOS will background what it was previously doing. I'm curious, why would you open MrMC yet want to keep an Airplay video playing?
