Trying to build thru xcode
Re: Trying to build thru xcode
OS X for dev purposes
- Everbrave
I seeamet wrote:OS X for dev purposes
- Everbrave
during the make, I get
Reversed (or previously applied) patch detected! Assume -R? [n]
a) what does this mean?
b) how to answer?
b) how to answer?
- Everbrave
cd iphoneos10.3_arm64-target; patch -p1 < ../0001-lavc-aarch64-simple_idct-fix-iOS-build-without-gas-p.patch
patching file libavcodec/aarch64/simple_idct_neon.S
- Everbrave
where can I do that? can you give me the path to the file please?davilla wrote: ↑03 Jun 2017, 14:49comment out the patch, the repo was force pushed and now includes the patch.
find tools/depends -name 0001-lavc-aarch64-simple_idct-fix-iOS-build-without-gas-p.patch
- Everbrave
- Everbrave
building 3.0.7 for iOS
I came so far in the make ...
Hunk #1 FAILED at 61.
Hunk #2 FAILED at 101.
Hunk #3 FAILED at 153.
Hunk #4 FAILED at 164.
Hunk #5 FAILED at 181.
Hunk #6 FAILED at 200.
Hunk #7 FAILED at 219.
Hunk #8 FAILED at 263.
Hunk #9 FAILED at 328.
9 out of 9 hunks FAILED -- saving rejects to file libavcodec/aarch64/simple_idct_neon.S.rej
make[2]: *** [iphoneos10.3_arm64-target] Error 1
make[1]: *** [ffmpeg] Error 2
make: *** [target/.installed-iphoneos10.3_arm64-target] Error 2
is it in ffmpeg again?
any advice is highly appreciated
