Trying to build thru xcode
trescatorce
Re: Trying to build thru xcode
Post by trescatorce » 02 Dec 2017, 18:28
Yes, I'm trying, but only appears "MrMC-TVOS-Lite" and "MrMC-iOS-Lite" then I've "MrMC --> My Mac (32 and 64 bits) and MrMC.app (same, My Mac 32 and 64 bits), what I doing wrong?
Post by davilla » 02 Dec 2017, 19:35
did you make xcode_depends ?
trescatorce
Post by trescatorce » 02 Dec 2017, 22:51
EDIT: I'm fucking idiot :lol: If I press 2 times to MrMC Project then I can see the MrMC-tvOS and iOS (not lite). Then I connected to my Apple ID and now I can build it.
Thanks again davilla.
Post by davilla » 03 Dec 2017, 14:29
HAHAHAHA :)
trescatorce
Post by trescatorce » 03 Dec 2017, 21:32
The last one (I think): how I can generate the deb file? If I try to build, the process finish but in terminal I get:
Off Topic
cd tools/darwin/packaging/ios
chmod +x ./mkdeb-ios.sh && ./mkdeb-ios.sh release
MrMC.app not found! are you sure you built release target?
I I do Xcode Menu -> Product -> Archive I can't locate the ipa file... it generate a folder named "build" (inside MrMC) with two subfolders: DebugLite-appletvos and Releaselite-appletvos.
Post by davilla » 03 Dec 2017, 21:43
we don't build deb files. so the script for building a deb might be old/outdated.
you might check Memphiz's yab branch for changes to support tvOS.
If you right-click on item created for achieve, there's a 'show in finder'
trescatorce
Post by trescatorce » 29 Dec 2017, 19:24
Hi davilla!
I want to summit and merge all patches (auto-refresh change, SDR/HDR, deinterlace with HW enabled...) into kodi krypton yab branch. Any ETA to pull the new 3.4.0 in github?
Thanks again for your work ;)
Post by davilla » 29 Dec 2017, 19:31
3.4.0 changed pushed out, sorry forgot to push them out after 3.4.0 got released.
trescatorce
Post by trescatorce » 29 Dec 2017, 19:33
Don't worry, thanks por the lighting reply ;)
Users browsing this forum: leonkoum, SUPERBIF and 7 guests
